2004 Z06 what fuel pump for E85?
Old Aug 26, 2019 | 11:40 PM
sic7's Avatar
sic7
Default 2004 Z06 what fuel pump for E85?
Trying to find a answer to what pump for E85 I could run in my 04 z
making 475 rwhp 455tq on stock pump and I’m going for a second round of mods
also will the stock 85mm maf be enough ?
milling the heads to get me 11:5 compression
A set of ported heads
trying to set it up for flex fuel
Old Aug 27, 2019 | 03:13 PM
INSTIG8R's Avatar
INSTIG8R
I believe OEM C6Z is an option for the pump setup. MAF should still be good at that point
Old Aug 28, 2019 | 12:00 PM
smitty2919's Avatar
smitty2919
Racetronix should have an option. I put their 225lph in my 95 Camaro I did E85/flex fuel setup on.
AFAIK, it's not so easy setting up a C5 for flex fuel...something about the PCM not supporting it? Oh and don't forget injectors.
Old Aug 28, 2019 | 12:50 PM
StingrayRebel's Avatar
StingrayRebel
I have 2 walbro 450s in mine, one of those might work depending on how much power you're after... I believe the hellcat pumps are walbro 525
Old Aug 28, 2019 | 01:49 PM
sic7's Avatar
sic7
From the reading I have done the p59 in my 04 will work just have to program and make some minor modifications
im gonna run lsa injectors
To 2004 Z06 what fuel pump for E85?
