Harmonic Balancer Replacement
Old Aug 28, 2019 | 06:58 PM
jman1335's Avatar
jman1335
Default Harmonic Balancer Replacement
Hi all,
getting my first c5 repair done, the harmonic balancer is wobbling a bit and the car shudders a bit when idling.
ive asked my mechanic to replace the balancer, bolt, seal, and both belts with OEM parts. As it’s a bigger job 4.5h labour), wondering if there’s anything else they should address while in there and with the steering rack off, etc.
its an 01 Coupe, 82,000km. Runs great but just wondering if like some other cars water pumps or anything should be looked at when up in and with that much taken apart.
would appreciate any advice!
Old Aug 28, 2019 | 07:15 PM
bigsapper's Avatar
bigsapper
I just had mine done and that's the exact parts I had replaced. Although with ATI 10% UD & ARP crank bolt.
Old Aug 28, 2019 | 07:38 PM
StingrayRebel's Avatar
StingrayRebel
I would not use another oem balancer or the same outcome may happen... I would also go with an arp bolt just in case you need to reuse it again later down the line... also a good time to do a cam swap if that is something you want to do
Old Aug 28, 2019 | 08:42 PM
Ed Ramberger's Avatar
Ed Ramberger
Use a Powerbond for street and fun or ATI if it's a stick getting flogged. Don't go OEM balancer again.
Old Aug 29, 2019 | 12:39 AM
jman1335's Avatar
jman1335
I’m mainly driving 2-4x a week, short trips, shows on weekends, etc. Mechanic suggested just getting the OEM one...is there really a noticeable difference between the Dayco or other aftermarket ones?
not really looking for the higher end racing ones/ HP gain, just the repair so it stops wobbling/ shuddering intermittently at idle.
Old Aug 29, 2019 | 09:04 AM
Gordy M's Avatar
Gordy M
the base Powerbond HB is a good replacement. The OEM is prone to separation and can go from 8000 to 108000 miles or 13000KM to 170000km while the Powerbond usually last more than 100,000 miles under normal use. Also, the ARP crank bolt is a stronger replacement than the Torque to Yield OEM bolt.
Old Aug 29, 2019 | 09:55 AM
Spaggs's Avatar
Spaggs
Sounds like your "mechanic" either wants repeat business from you like replacing the HB again in the near future, or he doesn't know much about C5 Corvettes. I'd try and find someone else to work on your car.
Just My 02 cents worth.
Spaggs
Old Aug 29, 2019 | 10:35 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I wont use OEM balancers! Get the powerbond and ARP Bolt!
Old Aug 29, 2019 | 10:57 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
https://www.corvetteforum.com/forums...d-to-know.html
Old Aug 29, 2019 | 12:27 PM
runner140*'s Avatar
runner140*
Nice find, thanks.
To Harmonic Balancer Replacement
