Exterior ambient air temperature sensor
Old Aug 29, 2019 | 08:18 AM
sdharon's Avatar
sdharon
2nd Gear
Default Exterior ambient air temperature sensor
Guessing the exterior sensor is bad outside air temperature is 80 degrees. Anyone else had this issue or suggestions
Old Aug 29, 2019 | 08:27 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Welcome to the Forum !!....are you in Alaska ????....LOL !!!....you have either an open in the circuit or a bad sensor....since it is a thermistor circuit you can jump the connectors 2 pins together and if it reads HIGH the circuit is good...maybe the connector came off...just guessing !!...and BTW don't try this jumping thing on anything other than a thermistor circuit (also your engine coolant temp sensor) cause you'll fry your PCM jumping a 5 volt reference circuit directly to ground !!
Old Aug 29, 2019 | 08:32 AM
sdharon's Avatar
sdharon
2nd Gear
Thanks I’ll check the connection & try cleaning it up before I replace the sensor
Old Sep 4, 2019 | 07:45 AM
sdsmock's Avatar
sdsmock
8th Gear
Had the same problem. New sensor fixed it.
Old Sep 4, 2019 | 09:23 PM
redzg's Avatar
redzg
When mine was missing, system read 69, so betting it's shot.
Old Sep 5, 2019 | 08:10 AM
BRAVO1's Avatar
BRAVO1
VETERAN
replaced mine and the connector was rusted from being wet......easy fix
To Exterior ambient air temperature sensor
