Steering problem C5Z06
Old Aug 30, 2019 | 02:39 PM
WoodyS's Avatar
WoodyS
4th Gear
Default Steering problem C5Z06
I just got a 2002 Z06 with 14,000 miles. On the first day a whining noise, like belt slip, started coming from the engine. The Chevy dealer confirmed there is a noise and said it needs a new power steering pump and quoted $1900 to replace it.
How can a pump die in so few miles?
I've driven it 300 miles. Nothing has been fixed, but the whining noise has stopped. Now, when the car is not rolling, it is hard to turn the wheel and it makes a growling noise when I do. The steering works fine while driving.
What do I need to know?
Old Aug 30, 2019 | 02:40 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
buy a used one from VetteNuts !!!
Old Aug 30, 2019 | 08:21 PM
Hitman227's Avatar
Hitman227
Don't take it to the Dealer - they're half-a**ed at best.
Old Aug 30, 2019 | 08:26 PM
pjdbm's Avatar
pjdbm
Have you checked the fluid? is there leaks? check for air in they system?
Old Aug 30, 2019 | 09:19 PM
WoodyS's Avatar
WoodyS
4th Gear
Fluid Ok. How do I check for air?
Old Aug 30, 2019 | 11:14 PM
pjdbm's Avatar
pjdbm
I meant air in the power steering system, but if no leaks or work was done, then doubtful it needs to be bled.
I do know that the price they gave you sounds crazy and if it turns out to be the pump, you can do it and save a lot of money.
Old Sep 3, 2019 | 01:46 PM
WoodyS's Avatar
WoodyS
4th Gear
It turns out the pulley on the steering pump broke. There is a splined metal sleeve still on the pump shaft but the pulley, which is apparently a casting, broke off. Possibly the sleeve became loose in the pulley making the noise. Possibly the pump is OK. Has anyone else seen this happen?
WoodyS
Old Sep 3, 2019 | 04:50 PM
gimp's Avatar
gimp
$1900? Doesn't sound quite right. I got an upgraded setup from Turn One with their billet pulley, at a higher rating for road course track, which was somewhere around $450 in parts cost. Install labor was a few hours, certainly not $1400 worth of labor.
Old Sep 4, 2019 | 10:15 AM
WoodyS's Avatar
WoodyS
4th Gear
Thanks Gimp for the info.
WoodyS
To Steering problem C5Z06
