Battery concerns
Old Sep 7, 2019 | 02:39 PM
jjc508520's Avatar
jjc508520
Default Battery concerns
I keep my battery on a tender while not in use it Is a die hard AGM. Today I went to charge it and just a click. The fuel pump, DIC, and underhood light all came on. I jumped it - ran it for about 15 minutes - made a quick stop - at restart I had a click but then it started on the second try.
I am on a 2h drive down to Atlantic City - what should battery volts read under normal circumstances? At the moment I’m getting 13.7 to 13.8 - should I get a new battery while I am on the road?
Old Sep 7, 2019 | 02:49 PM
heggsc5's Avatar
heggsc5
Sounds more like a potential starter issue to me. Voltage looks good. The "easy" guess/fix used to always be try a new battery first, but with how expensive batteries are now, not so much. For the cost of a new battery nowadays, you could pay the "diagnosis" fee at a shop which will usually also go towards the repair cost. I'm guessing starter issue, but maybe someone can chime in with "common issue" knowledge.
Old Sep 7, 2019 | 02:54 PM
jjc508520's Avatar
jjc508520
I’m up to 14 at highway speed - must have missed the connection or had the wall switch off
Old Sep 7, 2019 | 03:01 PM
heggsc5's Avatar
heggsc5
Glad it's looking good so far, that would have sucked to ruin your trip. FWIW my voltage is always between 13.3-13.8 max while driving depending on what the fans are doing, so if you're seeing 14, I wouldn't be worried about the battery haha.
Old Sep 7, 2019 | 03:08 PM
Moved to C5 Tech.
Old Sep 7, 2019 | 03:33 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Could be starter. I've seen/heard that click followed by nothing before. Check your starter connections. If any of them are remotely loose, you could get the click.
Old Sep 7, 2019 | 03:34 PM
mhanley's Avatar
mhanley
Is your battery tender made for charging AGM batteries ? AGM batteries do require a special charger. Also check your battery connections and see if any are loose. You might also have a bad alternator which can drain the battery. My 02 charges normally at 13.7-13.8 all the time and I run a AGM battery.
Mike
Old Sep 7, 2019 | 03:41 PM
JR-01's Avatar
JR-01
Check voltage at the battery with a voltmeter after it has sat for an half hour or so. It should be at 12.6 or more.
Old Sep 7, 2019 | 04:02 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you want to run the car up here to Monmouth County I can load test your battery and check the starting and charging system with my scope !!
Old Sep 7, 2019 | 04:08 PM
JR-01's Avatar
JR-01
Do this.
Old Sep 7, 2019 | 08:07 PM
jjc508520's Avatar
jjc508520
So I’m at Morton’s and I start yakking with a C6’er - telling me about a big event in Ocean City MD...
Old Sep 8, 2019 | 05:14 PM
jim993's Avatar
jim993
The start attempt with a click, then OK start on second try would point toward a failing starter solenoid or a failing ignition switch among others. The 14 volts en route sounds OK although voltage at the battery terminals may not be the same as DIC voltage
In my view, a bad battery usually won't provide an OK start on a re try. A loose or insufficiently tight battery side connection (FSM: 11 foot pounds) as well as corroded grounds can also present this symptom
One way to isolate would be, if a click, no start occurs, clonk the starter from above with a long insulated rod or dowel. Past pasts posts have indicated that this may allow the starter solenoid to make contact and allow a start. But not for very many more times before total failure.
To Battery concerns
