Hyper flash
Old Sep 8, 2019 | 11:54 AM
Ed Bard's Avatar
Ed Bard
Cruising
Default Hyper flash
Hyper flash:
Replaced my C-5 2001 hazard switch with the one listed below due to intermitted turn signals not working. I now have hyper flash on the turn signals but not when using the hazards. Any thoughts. I don’t have any LEDs installed and all the blubs are working. Thanks in advance for any help.
https://www.ebay.com/itm/New-Hazard-...72.m2749.l2649
Old Sep 8, 2019 | 12:14 PM
Ed Ramberger's Avatar
Ed Ramberger
Sounds like you have a bad ebay part if it doesn't hyperflash with the OE part. One note - you are certain that there are no LEDs and certain that no bulbs are burned out - correct?
Old Sep 8, 2019 | 04:50 PM
jim993's Avatar
jim993
Check it again after cycling the new hazard switch off and on 10 times, report back.
Old Sep 8, 2019 | 06:11 PM
Ed Ramberger
Interesting - are you thinking contacts in new switch need cycling?
Old Sep 8, 2019 | 06:41 PM
jim993's Avatar
jim993
I had intermittent turn signals and found that cycling the hazard switch cured the symptom temporarily. Later I drilled the front of the hazard switch, see post 17 in the following thread:
https://www.corvetteforum.com/forums...l-problem.html
and foamed the interior with CLP Break-Free, a corrosion preventative moisture excluding lube that I have used on guns for 30+ years. That cured the symptom for several months, although the symptom briefly returned and was again cured by cycling the hazard switch once. No symptom for the last year and a half.
Amazon Amazon
I have a Hyper Flash to insert in reserve if all else fails, check post 5 in the following thread:
https://www.corvetteforum.com/forums...-blinkers.html
Old Sep 8, 2019 | 07:01 PM
Ed Bard's Avatar
Ed Bard
Cruising
Will try.
Old Sep 8, 2019 | 07:30 PM
Ed Bard's Avatar
Ed Bard
Cruising
No LED installed or bulbs burned out. May have a bad part. I feel bad because I did not check all functions while I had it out. I may try the bypass cord.
Amazon Amazon
To Hyper flash
