Oil leak
Old Sep 19, 2019 | 05:03 PM
TorchRedLegend's Avatar
TorchRedLegend
Default Oil leak
My c5 smokes a lot from the back of the engine on the passenger side I know I have a oil leak but anybody know what it could be
Old Sep 19, 2019 | 05:59 PM
RB211's Avatar
RB211
If it is only on the passenger side, I would take a look at your valve cover gasket on that side. Pretty easy fix if it is.
Old Sep 19, 2019 | 06:44 PM
Rick369's Avatar
Rick369
Could be your oil pressure sensor.
Old Sep 19, 2019 | 06:57 PM
DDaaryl's Avatar
DDaaryl
Another vote for the oil pressure sending unit. I did at one time find a "mechanic" did not tighten my oil filter properly and have done my own oils changes since that event.
Old Sep 19, 2019 | 09:21 PM
Rick369's Avatar
Rick369
Not diagnosing anything. Just providing possible causes.
Old Sep 20, 2019 | 12:14 AM
TorchRedLegend
Gotta get the car on a lift and take a closer look I’ll keep everyone updated but the oil pressure is pegged to the max
Old Sep 20, 2019 | 05:56 AM
ZigZag's Avatar
ZigZag
Then oil pressure sending unit is most likely your problem. It's at the back of the engine near the firewall.
Old Sep 20, 2019 | 09:46 AM
TorchRedLegend
I hope so thats the least expensive out of the options
Old Sep 20, 2019 | 10:56 AM
knewblewkorvette's Avatar
knewblewkorvette
I highly recommend a relocation kit. Though not cheap, it's much better if you have a sender fail again. (and they do fail a lot)
https://corvetteparts.com/item/oil-p...hoC090QAvD_BwE
Old Sep 20, 2019 | 11:39 AM
VetteFTW's Avatar
VetteFTW
I just did this myself. Although that sensor is a different size from stock. Not sure which one to get to replace it when the time comes.
Old Sep 20, 2019 | 11:41 PM
Moved to C5 Tech.
To Oil leak
