Car will not crank over
Old Sep 25, 2019 | 01:15 PM
thevelvetglove's Avatar
thevelvetglove
Default Car will not crank over
Got in the car this am put the key in Heard the car prime, all normal lights went on inc HVAC went to turn the key all the way and nothing. it does not crank? any ideas where I start looking - thx
Old Sep 25, 2019 | 01:31 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Aloha again !!...just you ever get your car sorted out a few months ago ??...thought you had priming issues back then ??...get your battery checked and check your battery connections at the battery and down below !!
Old Sep 25, 2019 | 05:15 PM
thevelvetglove
Aloha and Hi C5 Diag, No still trouble shooting, just keep having other problems to solve with a 19 year old car. I will get to it and circle back to you.
Old Sep 25, 2019 | 06:01 PM
mmartinez's Avatar
mmartinez
As C5 Diag suggested have battery checked, check battery cables at the battery, and battery cable connection on starter solenoid, and what is your security light doing, it should flash a few times and then turn off before turning the key to start.
Old Sep 25, 2019 | 07:42 PM
C5 Diag's Avatar
C5 Diag
Unfortunately it will not get any better !!...especially where you live !!...Mahalo !!
Old Sep 25, 2019 | 08:14 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the chip in the key !!!!!! clean with alcohol or replace !!!
Old Sep 26, 2019 | 02:10 PM
thevelvetglove
Thanks everyone, I will get a new Key and check the battrey lines.
To Car will not crank over
