Issues with acceleration
Old Sep 27, 2019 | 04:12 PM
Saqib Sufi's Avatar
Saqib Sufi
5th Gear
Default Issues with acceleration
Hi folks,
After doing some radiator replacement and battery fix, I tried driving my base c5 2000 and found that the car slowly accelerates on its own up to 40mph. Likewise, if I am at a high speed and lift my foot, it drops to 40mph and stays there. What could be causing this?
Old Sep 27, 2019 | 06:47 PM
JR-01's Avatar
JR-01
Does it do it with the cruise control turned off?
Old Sep 28, 2019 | 02:15 AM
Moved to C5 Tech.
Old Sep 28, 2019 | 06:53 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Is it running strange? Any CEL's? Idle high? Need more info to get any kind of diagnosis.
Old Sep 28, 2019 | 07:00 AM
Saqib Sufi's Avatar
Saqib Sufi
5th Gear
The cruise control on the left blinker stick is at off position.
Old Sep 28, 2019 | 07:04 AM
Saqib Sufi's Avatar
Saqib Sufi
5th Gear
Running fine. Not sure what CEL is. It no codes thrown. Idle is a little over 1 which I think is low but the car accelerates and shifts to 2nd and third gears at that rpm. It is an auto tranny.
A few things I did in last month. Removed air intake and replaced the radiator. Deep cleaned the whole engine bay.
Diagnosed the battery drain issue to pop up headlight and disengaged it. Battery did die 3 times until I was able to isolate the issue.
Old Sep 29, 2019 | 05:39 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
It is idling way high for a stock car. When the engine is warm it should be around 600 to 700 RPMs at most. You could have a vacuum leak at the intake or somewhere else for that matter. Those can cause an increase in idle speed. That would be the first place I would start checking.
To Issues with acceleration
