Headlight motor replacement
Old Oct 3, 2019 | 08:43 PM
heggsc5's Avatar
heggsc5
Default Headlight motor replacement
Has anyone used an aftermarket headlight motor rather than replacing just the gear in their OEM motor? If so, do they hold up?
I have to do my driver's side and I'm looking at ~$50 for a gear kit or ~$60-80 for an entire aftermarket motor. I'm completely fine spending $20 extra to make it a quicker job since I have PLENTY of more important projects backed up that I'd rather get to. Just curious if they have any quirks or just don't last. My car sees a few thousand miles a year with maybe 40% of those being at night, I don't think I'll be wearing out even a cheap motor anytime soon. I just want to make sure it's not going to need to be replaced sooner than later haha. I'd be annoyed if I replaced a $50 gear in a 20 year old motor and the motor crapped out soon anyway.
Old Oct 3, 2019 | 11:00 PM
jrbartholomew's Avatar
jrbartholomew
a few years ago i bought 2 Cardone motors, they lasted about 2 years in my daily driver. ended up buying 2 kits with the brass gears and redid them. If you plan on keeping the car just buy the kits, not much more.
Old Oct 4, 2019 | 02:11 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Firebird motors for ~$50 have been working great with a bit of re-wiring. See here:
https://www.corvetteforum.com/forums...-tax-pics.html
Old Oct 4, 2019 | 10:06 AM
Moved to C5 Tech.
Old Oct 4, 2019 | 11:05 AM
wcsinx's Avatar
wcsinx
To my knowledge, none of those motor assemblies will come with brass gears. That's strictly an aftermarket modification. But on the other hand, my stock nylon gears lasted 16 years before the driver's side stopped reliably opening sooooo .... I rebuilt them with a brass gear kit just for peace of mind and because I wanted to see how they were put together.
Old Oct 4, 2019 | 04:14 PM
heggsc5's Avatar
heggsc5
Very nice! Are these AC Delco motors or aftermarket? Have any part numbers handy by chance? I'll try do some searching, just curious.
Haha that's exactly my rationale here...if the OEM gears lasted 18 years/almost 50k miles...I'm ok with another set of nylon gears. Paying $100 for a brass gear kit is cool and all, but the rest of the motor is still old.
Old Oct 4, 2019 | 04:36 PM
heggsc5's Avatar
heggsc5
Looks like eBay has the same motors (looks like the same case), but C5 specific, for $57. Just put in an offer on one for $50 haha. Worst case, I'll get the Firebird and swap the shaft and connectors like you mentioned. Pretty slick
Old Oct 4, 2019 | 04:50 PM
wcsinx's Avatar
wcsinx
Those motors are incredibly robust. I wouldn't be concerned about the vintage of the motor itself. It's the gears that give up. You can find brass gear kits on ebay for both sides in the $50-$60 range.
Old Oct 6, 2019 | 07:43 PM
c51stvette's Avatar
c51stvette
I purchased assemblies from Rock Auto. I think they carry the AC Delco brand
Old Oct 7, 2019 | 09:47 AM
jjc508520's Avatar
jjc508520
I bought on ebay from an outfit Atlantic Corvette - I learned too late - note the positions of everything when you're tearing it apart
https://www.ebay.com/str/atlanticcorvetteparts
One of the motors had excessive end play and they exchanged it no questions....
Old Oct 8, 2019 | 07:30 PM
heggsc5's Avatar
heggsc5
Just ended up buying a new aftermarket one from eBay for $55. With so many backed up projects right now, it's worth a few extra bucks to not have to bust them both open to swap out the shaft and connectors haha. Fingers crossed I won't be swapping the OEM motor back into it with a new metal gear sooner than later
Old Oct 9, 2019 | 10:14 AM
lonerider2002's Avatar
lonerider2002
For what it's worth, I contemplated on buying another motor or gear set when my drivers side started failing and found it to be much easier to just take the arm off of the spindle and rotate the gear 180 degrees by turning the adjustment ****. I also flipped over the two bump stops and now it works like new. I figure I'm good for another 12-15 years or so. Cost of repair---$0.00.
Old Oct 9, 2019 | 11:14 AM
STRMLNE's Avatar
STRMLNE
I bought one from autozone for $139. It’s actually quieter and runs smoother than my oem motor. I’ve had it about a year now. Everything still works great.
Old Oct 9, 2019 | 03:34 PM
heggsc5's Avatar
heggsc5
Well crap. I was going to rotate the gear, but I figured that required removing the cover, removing the gear, and repositioning it haha. Maybe I'll try that before I install the new motor
Old Oct 12, 2019 | 03:39 PM
heggsc5's Avatar
heggsc5
Update for future info seekers:
I removed the OEM motor last night, rotated the shaft 180 degrees to try the other side of the gear as mentioned above, and unfortunately it just went from spinning/grinding after the lights finished going down to spinning/grinding after the light finished going all the way up. I think if maybe I would have caught it earlier like lonerider2002, it may have worked. Luckily, I had the replacement motor ready and just swapped it out. eBay aftermarket motor is working like a champ so far
Old Oct 12, 2019 | 03:48 PM
STRMLNE's Avatar
STRMLNE
Probably depends how many teeth are damaged as well. I don’t think rotating the motor would work for too many people. I tried that on both my motors that went bad recently (almost at the same time which is wild) and it didn’t work for either.
Old Oct 12, 2019 | 03:53 PM
heggsc5's Avatar
heggsc5
That's probably exactly right. The good thing is, if you have a replacement motor or gear handy, it's worth taking another 10 minutes to at least give it a shot. If it works, return the replacement motor or hold on to it just in case
To Headlight motor replacement
Old Oct 12, 2019 | 11:44 PM
jdmvette's Avatar
jdmvette
Night Owl for life
For me, the eBay aftermarket motors are the screw down type vs my OEM sealed motors which makes future gear replacement a breeze
Old Oct 13, 2019 | 11:27 AM
GCG's Avatar
GCG
Plastic and rubber degrade with age and heat. As already mentioned, some people have had success by just rotating the motor's gearbox output shaft 180° to use the undamaged section of the plastic gear, but it's important to understand that YMMV... don't expect another 20 years
Old Oct 16, 2019 | 04:45 PM
unlvrebel's Avatar
unlvrebel
Aren't the aftermarket ones all just remanufactured AC Delcos? So in the end, you're getting a stock motor that was probably grabbed off the heap and a new nylon gear was put in it...
