HVAC problem
Old Oct 4, 2019 | 01:01 PM
zzcop8's Avatar
zzcop8
Default HVAC problem
I have a 2000 C5 convertible. Today when I went out the wife asked why the heat was on her side. My side the vents where blowing nice cold air but the passenger side vents where blowing hot air. Where do I start looking to repair this? I prefer not to just throw parts at it until it is fixed, just need to know where to look. Thanks in advance
Old Oct 4, 2019 | 01:51 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
blender door actuator, one for each side, I hear the pass side is easy to replace ???? can remove the fuse or disconnect batt to see if it re-aligns ???
Old Oct 4, 2019 | 01:53 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
a few threads on this !!!!
Old Oct 4, 2019 | 02:58 PM
zzcop8's Avatar
zzcop8
Where do I find these threads, I have been unsuccessful in my search?
Where is the passenger side Blender Door actuator located?
Old Oct 4, 2019 | 03:16 PM
zzcop8's Avatar
zzcop8
Well while I was checking things earlier I pulled the two HVAC fuses #18 & #27, both where good, then replaced them.
. After I posted this info request and saw pulling the fuses might reset the Actuators I went to the garage started the car and now all are working like they are supposed to. Thanks again for the info.
Old Oct 4, 2019 | 03:20 PM
OneFast1's Avatar
OneFast1
Left of the glove box high up under the dash. You may be able to see it if you remove the glove box or the radio as it sits between the two. Removing the dash cover is maybe a 2 out of 5 on the difficulty scale.
To HVAC problem
