My manual shifter is really difficult to shift smoothly or rapidly. Clunky and crunchy are words that come to mind. I had a Corvette tech check it and he said it was fine. The car shifts smoothly when not driving. The tech said make sure your clutch is completely down to the floor. I'm really a conservative driver and won't push a car until I get a good feel about how the car shifts. I DO NOT want to end up with an expensive repair! Any mods or ideas you guys know of? Thanks Scott
Also, fresh fluid helps. Not hard to change, or have a shop do it. Most notice a nice improvement.
An aftermarket shifter (top shifter box) is simply a lever. There aren’t detents in the mechanism that change feel, usually only geometry changes but that has nothing to do with notchiness.
The washer/anti-venom mod is one thing, but fresh fluid can never be a bad idea.
Hurst shifters aren't well sealed. It might be time for a cleaning in addition to all the above. Take the shifter apart, clean everything and re-grease.This will make a big difference.
Hurst shifters also have different springs and adjustments for those springs. If you have the stock springs, try the softer ones. If you have the softer ones, try using only one on each side (the larger outside ones). Try adjusting the spring tension using the two torx screws on the top of the casing.
Huh. Learn something every day. I've had the same hurst in my car since May of 2006. I've never had a complaint about it but if I can smoothen it up some then I may explore these options (no need to do the AV mod on my car, there's a TR6060 in there now).
I've had a Hurst in my C-5 since 2002, and have been very satisfied with it. I did, however, when I first installed it, take quite a bit of time fiddling with the adjustments, just to get the right feel. I also made sure that the "neutral gate" was properly adjusted. To the OP, look up "shifter adjustment" on this forum. And for what it's worth, I've never performed the "anti-venom mod".....
I still have the stock shifter, but wanted to mention that I recently swapped out the original factory DEX3 to Amsoil Torque Drive and noticed a fairly significant change to how it shifts. Almost all the notchiness is gone. As others mentioned, it might be worth changing fluid if you've not done so already.
I second that recommendation!! That's the first place to start. It will take 4 qts BUT, you will only be able to drain and refill 3.75 qts. Fresh quality ATF makes a very significant improvement in shift quality.
You mean manual transmission fluid though right? We all know what ATF stands for. I only have 28000 miles on the car BUT it is 17 years old.
YES! The C5 MN-6 / MN-12 manual transmissions uses ATF (Automatic Transmission Fluid) as the gear box lubricant! It specifies DEXTRON III but, if you use the AMSOIL Torque Drive, its compatible with ALL the C5 manual transmissions.
NOTE!! The early C5s (97-2000) can only use the old DEXTRON NON Synthetic ATF or equivalent. The Late model C5s 2001-2004 can use synthetic ATF. AMSOIL Torque Drive is compatible with all.
Mine is same age as yours. These manual transmissions take ATF. If you look underneath at the transmission you'll see a sticker saying Dexron III. If you do some searching you'll see many options for fluid that can be used in our transmissions - but whatever should be Dexron II based. I ended up using the Amsoil product as it seems to be the product of choice for many here on the forum.
gotcha thanks but would I need to change it at 28000 miles?
OK thanks for that. Things have changed a lot in 43 years lol! Still I've read quite a few owners manuals that don't recommend a fluid change for a long time unlike an automatic transmission.
Thank you! 3.75 quarts? Is that where you fill it until the fluid starts to come out of the overflow outlet?
