Longer Wheel Studs
Old Oct 9, 2019 | 07:01 PM
badazz81z28's Avatar
badazz81z28
Default Longer Wheel Studs
I'm looking for longer C5 wheel studs...Not necessary longer, but more thread. The stock stud would be perfect if the last 3/8" of it was actually threaded instead of a nose. I tried the DRM/Dorman 1/2" longer studs and they are slightly too long and wont install without removing the hub (too much work). Any solutions found?
Old Oct 9, 2019 | 07:43 PM
StingrayRebel's Avatar
StingrayRebel
arp but like the ones you tried you will most likely have to remove the hubs to out them on... if you are careful you can cut some material off of the longer ones to make them the size you need
Old Oct 9, 2019 | 11:26 PM
jdmvette's Avatar
jdmvette
Night Owl for life
I use ARP extended bolts but yeah if stock length was threaded all the way that extra thread or two would help you out.
To Longer Wheel Studs
