Short Throw Shifters
Old Oct 10, 2019 | 04:24 PM
Rvajma's Avatar
Rvajma
Default Short Throw Shifters
I'm considering putting a short throw shifter into my 2004 Z06. My local speed shop recommended an MGW. Other than that I don't know where to start. Any advice/recommendations/warnings?
thanks in advance
Old Oct 10, 2019 | 05:00 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
MGW is only one that comes with the lower box (which is everything) best choice hands down !!!!!
Old Oct 10, 2019 | 07:11 PM
Rvajma's Avatar
Rvajma
Is this a do it yourself job? I watched the installation videos and they seem pretty straightforward. Of course, they are professionals who have done it over and over and attacking it for the first time might not be as easy.
Old Oct 10, 2019 | 07:52 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
my wife did our C 6 Z in less than a hour !!!!!!
Old Oct 10, 2019 | 08:44 PM
Rvajma's Avatar
Rvajma
Wow! Successfully I take it?
Old Oct 10, 2019 | 09:08 PM
Xlevanx's Avatar
Xlevanx
Super easy. Once you remove the plastic center section radio bezel whatever it’s called, four bolts and it’s out. Very basic you got this!
Also have the mgw it’s a nice unit
Old Oct 10, 2019 | 10:09 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
yes !!!!!!!
Old Oct 12, 2019 | 10:11 AM
MacA1979's Avatar
MacA1979
Always Shiftin'
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (stock)
I totally agree. MGW's "system" is quality made, but scares some people off because of cost. But considering everything you get over the other aftermarket options (lower box , alignment tool, ...) you are actually getting a MUCH BETTER deal!
Old Oct 12, 2019 | 10:44 AM
jackthelad's Avatar
jackthelad
It all depends what you want out of it. Shorter throw - given. Effort - prepared to have a higher effort or want light shifting? Budget? The very best thing to do would be to try to sample an MGW or other shifter, such as the C6 set up before you buy.
p.s. find a C6 on a lot and take it for a test drive...that will tell you whether you like that shifter or not better than anything.
Old Oct 13, 2019 | 02:08 PM
Rvajma's Avatar
Rvajma
Thanks. You're saying the C6 has a short shifter? Or the C6 shifter is another option?
Old Oct 14, 2019 | 12:13 PM
jumpmanmb87's Avatar
jumpmanmb87
What Shifter post #768409303030
Old Oct 14, 2019 | 03:25 PM
jackthelad's Avatar
jackthelad
A lot of people seem to like the C6 box/lever/**** combo and have chosen it over any of the "after market" options. I am just suggesting you need to try a few different options if you can, including that setup.
Me? I chose the "blue light special" option, after trying a couple alternatives - a cut down C5 lever with a different **** on a rebuilt box. Shifts are shorter throw but with minimal extra effort, and the C5's "truck like" shift **** is thankfully no more.
By the way, some people report across-the-gate "slop" with the standard set up. That's because there is slop in the transmission itself - not in the shift mechanism. Wiggle the lever around with the trim removed and you can see what goes on.
Old Oct 23, 2019 | 01:04 AM
Cody Carlson's Avatar
Cody Carlson
7th Gear
Consider the antivenom mod when looking at an aftermarket shifter! It will make shifting a lot easier on your arm if you find that the new one is a little tight feeling.
Old Oct 23, 2019 | 08:38 AM
Rvajma's Avatar
Rvajma
Thanks. What is that? I've seen a few references to it but don't know exactly what it is.
Old Oct 23, 2019 | 10:16 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
https://www.corvetteforum.com/forums...procedure.html
Old Oct 23, 2019 | 10:36 AM
Rvajma's Avatar
Rvajma
Thanks, that is a great site. Lots of good info there.
Old Oct 23, 2019 | 10:47 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Love my MGW. Never replaced the lower box, but my car only has 38k miles.
To Short Throw Shifters
Old Oct 23, 2019 | 11:10 AM
Rvajma's Avatar
Rvajma
Thanks. Gotten lots of good feedback about it, think I will make it a winter project. Did you do the anti venom mod?
Old Oct 23, 2019 | 11:44 AM
MetalMan2's Avatar
MetalMan2
I installed a MGW (upper + lower) about 2 weeks ago, which replaced a C6 upper shifter and T-Mod Customs lower box.
MGW is a much shorter shift. I'm still using the C6 ****, but I prefer the C6 shifter's placement of the ****.
Overall the MGW is very nice and tight, but I REALLY need to do the anti-venom mod... have the washers sitting on my workbench.
It takes quite a bit of effort to reach 5/6 & reverse. It's possibly worth mentioning that I'm 30 and lift weights somewhat regularly.
Since I have plans to replace the reverse lockout solenoid anyways, I also have a softer spring for that coming today:
https://core-shifters.com/products/s...ant=8019904451
Old Oct 23, 2019 | 12:54 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Yes, with one washer.
