Alignment
Old Oct 17, 2019 | 01:06 PM
Rvajma's Avatar
Rvajma
Default Alignment
I just noticed my steering wheel is off about 10 to 15 degrees when the car is tracking straight. I don’t remember it being that way during my recent track day but it’s possible. Does this indicate an alignment problem? Tire problem? How important is it to correct is ASAP?
Any thought maybe would be appreciated.
Old Oct 17, 2019 | 01:34 PM
MetalMan2's Avatar
MetalMan2
If it is an alignment problem (with toe), then your tire(s) can/will wear down significantly faster. I learned this the hard way with a past car; wasted a pair of front tires in under 1000 miles because I was too cheap to get an alignment.
Of course, there's no way to know if it's an alignment issue without checking alignment.
Old Oct 17, 2019 | 01:45 PM
Rvajma's Avatar
Rvajma
Sounds like it is worth a look. It is set up with negative camber now and seems to handle fine.
QUOTE=MetalMan2;1600335184]If it is an alignment problem (with toe), then your tire(s) can/will wear down significantly faster. I learned this the hard way with a past car; wasted a pair of front tires in under 1000 miles because I was too cheap to get an alignment.
Of course, there's no way to know if it's an alignment issue without checking alignment.[/QUOTE]
Old Oct 17, 2019 | 03:57 PM
69autoXr's Avatar
69autoXr
Could be a slipped control arm (camber, caster) eccentric. If you had your eccentrics marked this would be a quick check and fix.
Also could be a tire. I was at a track day last year and had a radial belt break in a rear tire halfway through a session, had to keep the wheel turned to keep going straight. That was an interesting experience.
Old Oct 17, 2019 | 04:09 PM
67Ranger's Avatar
67Ranger
The eccentrics tend to move with track use. I'd recommend marking them so you can get them back in position easily, or going with a camber kit that will make them unable to move.
Old Oct 19, 2019 | 06:43 PM
Rvajma's Avatar
Rvajma
good idea, I will check that. thanks.
To Alignment
