04 Z06 rear diff movement video
Old Oct 19, 2019 | 10:20 PM
wydopnthrtl's Avatar
wydopnthrtl
Default 04 Z06 rear diff movement video
Today I mounted a camera near the rear diff and did some different types of driving. Just thought its interesting and y'all might like to see what a stock 04 Z06 does.
Old Oct 20, 2019 | 08:15 AM
CinciZ06's Avatar
CinciZ06
Awesome video! Now I’m truly glad I picked up an HPI mount to throw on when I do the clutch.
Old Oct 20, 2019 | 09:13 AM
dskinsler83's Avatar
dskinsler83
But all of that is also what keeps you from feeling driveline vibrations which will become very evident with the solid mount. Even regular harmonics of the driveline while cruising. All in what you can tolerate.
Old Oct 21, 2019 | 06:10 AM
wydopnthrtl
True, in OEM engineering we have NVH targets. In a sports car the feeling (aka "HMI") that team wants the driver to sense is intentionally tuned. We do that with MANY factors like with auditory, steering, seating, throttle response, the feel of the seats & steering wheel, visibility, ect... and driveline isolation. Then on top of that we have longevity targets (I think GM used 10yrs / 200k miles during the C5 development?)
One thing I was a bit surprised at is how much the diff moves laterally. In this vid I was turning left moderately quick. Definitely quicker than most traffic would turn. Next time I do this I might do some HARD cornering.
Old Oct 21, 2019 | 04:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It didn't move near as much as I thought it was going to. EXCELLENT WORK!
Maybe you can get a vid of the left or right side A ARMS, CV shaft and wheel assy and support linkages in the same type of test. That would be interesting. Especially with the wheel hop and wheel spin in heavy acceleration.
Old Oct 22, 2019 | 07:16 AM
wydopnthrtl
I've been thinking or getting a second camera and recording both the tire and the diff at the same time.
One thing that is noticeable is the fore-aft movement. Since its all bolted together that means the engine must be moving that direction and amount too.
Old Oct 22, 2019 | 04:28 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You BET YA!! My thought is your engine mounts are most likely SHOT or well worn! Do a power brake or a quick release of the clutch while someone watches the drivers side engine mount. If the engine pops up a LOT, that mount is toast. My buddy's 2000 C5 Coupe A4 had a completely separated mount!
Bill
Old Oct 23, 2019 | 02:46 AM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Great video wydopnthrtl
Yep, the stock mount is very soft and allows a lot of movement to go on. Its designed like the for a comfortable quite ride, but its not good for performance.
Bill is right, you should also check the motor mounts, especially the driver side.
Because the stock isn't the best in the performance department, we have developed our LUX High Performance Trans/diff mount.
We designed it with a substantial amount of Polyurethane to keep the noise and vibration down, yet it is firm enough to keep the trans/diff movement under control .
If you would like more info on it, here is the link. www.saccitycorvette.com/C5LUXMount.html
Thank you,
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
To 04 Z06 rear diff movement video
