Weirdest thing. Need help
Here's the problem that has me like what the hell.
Also note. it has a new yellow top battery.
Any help would be greatly appreciated.
Here's the deal/issue
open door get in car. I have power, headlights work, radio works, dash light up ect.
Turn key to start. Just clicks once, then there is absolutely no power car acts as it would if there was no battery. Everything is dead, no lights, nothing that requires power works.
If I disconnect and reconnect the negative terminal on the battery, I gain back everything electrical again. Until you try to start the car. Then everything repeats. One click, everything then dies until the negative terminal is disconnected/reconnected again.
Anyone know what the heck it could be?
Check the B+ terminal at each of the fuse boxes. The under hood fuse box has the feed through for the passengers fuse box.
Check the complete negative battery cable and its connections to the engine block and at the G-104/108 stud on the top of the frame just inboard of the battery.
The actual battery cable NEG & POS had been issues on some C5s. The CRIMP connection inside the colored plastic boot/covers go bad and corrode.
Last but not least, I've seen batteries fail just like you are experiencing. Put a meter on the battery terminal bolts and see if you have battery power when you experience the issue.
Bill
