Reverse lights switch - which one?
Old Oct 22, 2019 | 09:37 PM
bwill03z's Avatar
bwill03z
Default Reverse lights switch - which one?
Need to replace the switch on the tranny for the reverse lights. I am seeing different ones from different websites with prices ranging from $8 to $50. Can someone tell me the correct part number? I’ve found two part numbers on the forum, on amazon one is $11 and the other is $48. What’s the difference?
Old Oct 23, 2019 | 01:22 PM
photonhunter's Avatar
photonhunter
Active Streak: 90 Days
Why don't you post links to what you're referring to?
Your chances of getting an informed, intelligent answer will be improved.
dan kowall
Old Oct 23, 2019 | 04:33 PM
bwill03z's Avatar
bwill03z
dan kowall
Here is the one I started to buy. The other part number I was talking about in my original post was for a C6 apparently... this the correct one?
https://www.amazon.com/ACDelco-14069600-Original-Equipment-Back-Up/dp/B000EQQMHU/ref=asc_df_B000EQQMHU/?tag=hyprod-20&linkCode=df0&hvadid=312057677264&hvpos=1o8&hvnetw=g&hvrand=17010885310575116686&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9008804&hvtargid=pla-568794899686&psc=1 https://www.amazon.com/ACDelco-14069600-Original-Equipment-Back-Up/dp/B000EQQMHU/ref=asc_df_B000EQQMHU/?tag=hyprod-20&linkCode=df0&hvadid=312057677264&hvpos=1o8&hvnetw=g&hvrand=17010885310575116686&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9008804&hvtargid=pla-568794899686&psc=1
Old Oct 24, 2019 | 10:57 AM
photonhunter
That's the one I used in my 1999.
Not that it's 100% accurate, but did you put information about your car into Amazon's query box? That should tell you if it's the correct part for your car.
Alternatively, if you go to a GM parts site you can look up the correct part number for your car and buy it wherever you want.
dan kowall
To Reverse lights switch - which one?
