Engine sputters, gauges go crazy
Having a problem with my car (99 manual car with an 02 EBCM(problem did not begin when the EBCM was replaced)) where every now and then (every 30s to 2mins) the engine sputters (dies if it's at low rpm) and the gauges (oil, coolant, tac, etc) spike and come back.
The grounds are good, most problematic ones are crimped.
I have a lot of "U" DIC codes and I'm thinking the PCM is the culprit because most modules show a U1016 and the PCM has no trouble codes.
Here's a list of the codes with the modules that show it:
1000 TCS, SDM
1016 TCS, BCM, IPC, SDM, LD, RD, RFA
1040 IPC, SDM,
1064 IPC, SDM, HVAC, LD, RD, RFA
1088 IPC
1096 BCM, SDM,HVAC, LD, RD, RFA
1160 HVAC
1176 IPC
1255 HVAC, LD, RD, RFA
1301 SDM
Any advice is welcome but I doubt it being the battery or the grounds.
I'll swap the ignition switch later today (i bought one a while back trying to solve a different problem and it wasn't that, but I still have it. )
Keep the suggestions coming.
!!...you can find the 2 splice packs (pictured with both bus bars removed) near the BCM and remove the bus bar that connects all the serial data lines together and clean them with some emery cloth
Today I replaced the ignition switch, nothing changed.
Will clean the CAN splice again and see what happens.
Also got an ECU so I'll swap that to check it off the list.
https://www.corvetteforum.com/forums...re-report.html
The problem is back. It happens way more rarely, but it still happens.
According to the manual, G106 (ground between battery and engine) grounds S120(the splice pack I mentioned being the problem) and S120 grounds 4 wires for the PCM.
The problem is S120 is now soldered and is definitely not the problem. G106 is clean and tight too. Ignition switch is replaced.
When I replaced the PCM, i was getting a security light and it would start and die immediately. Is there a need/procedure to teach it my key? I was under the impression that the key info sits in the BCM.
The PCM that you purchased should have been flashed if the place that you got it from was worth its weight in salt. But if it isn't you will have to have it flashed. I know someone that you can send it to if you cant find someone locally.
You can try to handshake the BCM/BCM using this procedure. Just make SURE that you have a good fully charged battery or put it on a charger for the time it take to do the procedure:
https://moduleexperts.com/gm-securit...arn-procedure/
Today i cleaned the ground near the passenger headlight and the one near the passenger door hinge and the splice under the passenger airbag.
No change.
So far I haven't gotten it to do it continously on the driveway. It goes off without me touching anything and comes back in 5-60 seconds without me touching anything. I'll measure the serial voltage next time to see what's what.
I deducted that something in the door or door wiring was the issue. When it did it again, I opened the door and I SHOOK the wiring harness that runs through the rubber accordion tube between the door and body. PRESTO, Problem gone.
Popped the rubber accordion tube out and fished out the TWO door electrical connectors out of the hole in the door A pillar. There are two connectors. One is the SIX PIN POWER CONNECTOR! That is the one that gives the C5 these issues. The problem is caused by the female pins spreading apart and making poor contact with the male pins. This causes the door control module to turn ON and OFF, ON and OFF rapidly due to the **** poor connection and that causes the serial data buss to corrupt.
I bent the female pins so the little tong inside the female pin made solid contact with the male pin PROBLEM SOLVED!
To really determine if the female pins are damaged, you need a free male pin to do a male to female pin PUSH / PULL test to insure that the connection is tight between the two pins.
The other connector normally doesn't cause any issues. Different type of connector.
Just my experiences and 2 cents. If you look at the serial data buss with a scope, you would most likely see the corrupted data signal when the issue happens. Also when you pull up the DTC, you normally see a bunch of NO COMMS messages. Especially between the DCMs and BCM
Today's findings: got it to freak out on the driveway.
Windows and door control don't work. ALL the modules are no comm.
Measured the voltage on both star connectors, 4.7isg VDC. disconnected the one with 4 wires, no change.
Opened the passenger door, closed it. Everything is good.
And now the star connector voltage fluctuates, as it should.
The 6 pin connector was serviced before and looks normal but to make sure it's the door, can I unplug both door connectors for a couple of days? Or disconnect its wire to the star connector?
