Differential Rebuilder/ Replacement
Old Nov 5, 2019 | 11:27 PM
foggy's Avatar
foggy
Default Differential Rebuilder/ Replacement
Looking for best options to rebuild/replace 3.42 Differential for M6. 2003 Model, so it's a 3 rib.
I've looked at Zip Corvette options. And RKT, RPM as well.
Really just want a "stock" type build, but with upgraded bellville washers and C6 shafts.
Please give me some options !!! Thanks !!
Old Nov 6, 2019 | 07:15 AM
INSTIG8R's Avatar
INSTIG8R
If you're not trying to replace the ring and pinion or change the critical setup with a C6 pinion support, the rebuild can be done yourself pretty cheap. C6Z shafts will run you about $300 for both sides, and the upgraded bellville washers and C6Z clutch packs about another $450. There are a few pretty good write ups that show you how to do everything.
If you don't want to do it yourself, I'm also a fan of Murica Performance rebuilds. Jared has helped a lot of C5 guys out
Old Nov 6, 2019 | 11:20 AM
foggy's Avatar
foggy
Thanks for the info !!! I'm going to pull the diff.. But I don't want to do the internals myself.
I've got the really bad R &P whine.. Its shot... It's my Friends' car with low mileage, but he's not the orig owner.
So I need to find someone to send this to or do an exchange rebuild
Old Nov 6, 2019 | 11:21 AM
foggy's Avatar
foggy
Is Murica in Georgetown Kentucky??? doing a search for them
Old Nov 6, 2019 | 01:08 PM
INSTIG8R's Avatar
INSTIG8R
Yep, that's them. Jared Allen on facebook is the owner/operator and is pretty easy to get ahold of. Lots of satisfied customers and he has some of the lowest prices from what I've seen
Old Nov 6, 2019 | 04:31 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
http://www.vettenuts.net/ ether they can sell you a good replacement or get yours rebuilt ????
Old Nov 10, 2019 | 11:39 PM
jdwtx85's Avatar
jdwtx85
Jerod Allen @ Murica or Jason @ Texas Drivetrain Performance
I bet though no one can touch Jason's prices!!
Old Nov 16, 2019 | 10:17 AM
Nyt_Muves's Avatar
Nyt_Muves
FWIW I have over 20K miles and 3 years on my Zip Racing rear end with 4.10 gears. It has been FLAWLESS.
Old Nov 16, 2019 | 02:58 PM
GUSTO14's Avatar
GUSTO14
You might want to try sending a PM to tracdogg2 (Mike Dyer) out of Garland Texas. If he can't help you, he will know who can.
It appears Mike hasn't posted in a while, has anyone heard from him lately?
GUSTO
Old Nov 16, 2019 | 06:02 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Rick Kim of RKP does and excellent job. He will build it as mild or wild as you desire!
If nothing else give him a call and pick his brain, get a couple rebuild/price options and make your decisions after that.
He is good people!!
Bill
Old Nov 17, 2019 | 10:25 AM
helga203's Avatar
helga203
He is good people!!
Bill
This
Old Nov 17, 2019 | 03:50 PM
Dan H.'s Avatar
Dan H.
St. Jude Donor '17
He is good people!!
Bill
Another vote for Rick, he rebuilt my diff and I couldn't have been happier with the entire experience.
Old Nov 20, 2019 | 06:36 PM
Time for a C-5's Avatar
Time for a C-5
Follow the break in instructions. It matters. You don't even need to ask me how I know.
While you're at it, a little extra gear is lots of fun. Good luck.
Old Nov 25, 2019 | 07:03 AM
kalayaan12's Avatar
kalayaan12
Adding a 3rd vote for RKT...
If you're going to have differential work done, it's not a bad time to consider a different gear set. I went with a 3.90 rear from Rick about 5 years ago and have been extremely satisfied with it ever since!
Best of luck!
Jeff
Old Nov 26, 2019 | 09:27 AM
Dan H.'s Avatar
Dan H.
St. Jude Donor '17
Best of luck!
Jeff
I considered 3:90's or a different 5th gear in the trans. Has it helped your times? I felt talked out of it because it would require more shifting which can slow you down even though you may feel faster. Interested in you POV from someone who has done it. And because my driveline is coming out
Old Nov 28, 2019 | 02:57 PM
Big_George_S's Avatar
Big_George_S
Best of luck!
Jeff
Old Feb 4, 2020 | 02:41 PM
foggy's Avatar
foggy
He is good people!!
Bill
Hey Bill,
Do you mean RKT ??? I can't find anything that's RKP
Old Feb 5, 2020 | 04:38 AM
02general's Avatar
02general
Hey foggy, yes it’s RKT and there in Frederick Maryland
To Differential Rebuilder/ Replacement
