Hiss between shifts
Old Nov 6, 2019 | 07:10 AM
davidbeaver's Avatar
davidbeaver
Default Hiss between shifts
I have a 99 coupe 6 speed with around 130k and recently I’ve noticed a hissing sound between shifts that is very audible when the car is cold. It seems to go away after some time but always is there during the first 30 minutes of driving. I am also experiencing some high idle when coasting to a stop, then it will idle back down to normal. I’ve done some research and I’ve seen some posts that talk about air coming out of all the vents no matter what position the selector is in, however I’m not experiencing that problem, just hearing the hissing. I did spray brake cleaner around the intake and throttle body while it was idling but never heard any difference in idle. Maybe it’s normal but I don’t think so. Anyone experiencing the same problem and know where I should start looking?
Old Nov 6, 2019 | 08:09 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you can actually hear it must be a pretty big leak...the high idle is indicative of a vacuum leak and you can check the brake booster and PCV area...if you want to find it quickly it may be worth it just to take the car to a shop that has a smoke machine...you can find it quickly with that method and with a scan tool if you see your long term fuel trims high at idle that would nail down a leak too !!
Old Nov 6, 2019 | 09:20 AM
davidbeaver
That's a great idea! I will call around and see who has a smoke machine. The reason I was wanting to see if anyone else had figured this out is because most vacuum leaks I have experienced were audible under acceleration, not when you are letting off the gas like you would between a shift. That is when this hissing sound is most audible on my car.
Old Nov 6, 2019 | 11:23 AM
C5 Diag's Avatar
C5 Diag
A leak will mostly be heard at idle because that is when there is the most engine vacuum....as the throttle plate is opened engine vacuum will decrease...if you smoke a big fat stogie that can work too as a smoke machine...just blow the smoke into a vacuum line....LOL !!!
Old Nov 6, 2019 | 03:21 PM
foggy's Avatar
foggy
I would also check the lines to the Air Injection System.. They are at the pump, air filter housing, and exhaust.
The fresh air pump usually just runs on the cold engine.. so if it goes away once hot...?????
Old Nov 7, 2019 | 06:39 AM
davidbeaver
Foggy, I removed the AIR pump several months ago due to it not working at all. It was actually full of water and was throwing the 1410 code so I pulled it all out, plugged the holes on the exhaust manifold with block off plates, then had a tune done to remove the code. My mechanic put it on his diagnostic tool yesterday to see if there were any lean conditions and didn’t see any. I still want to throw some smoke at it soon.
Old Nov 8, 2019 | 10:37 AM
foggy's Avatar
foggy
Make sure to update this thread when you smoke test it and find the issue
Without follow up, none of us can learn and pass on the info !!!
Old Nov 9, 2019 | 10:14 PM
bobgroger's Avatar
bobgroger
Could be a noisy throwout bearing?
Old Nov 11, 2019 | 09:27 AM
davidbeaver
Thats a good question, I want to do a torque tube rebuild at some point next year just so I have the peace of mind that everything is in good shape. I purchased the car with around 120K on it so I know its probably due a rebuild and a new clutch. I knew the original owner and he did take very good care of the car, thats why I didn't have any hesitation on buying the car, he had the complete history of everything that had been done to it. I built a homemade smoke machine last night and am waiting on the sealant to dry so I can run some smoke this evening and see if I can find a leak. I'll definitely keep you posted.
Old Nov 12, 2019 | 10:06 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
I have similar in the cold on my 99. I have determined it is not the engine at all. If I depress the clutch, no noise. It is only as I move the shifter and reengage the clutch. Sort of a low hydraulic noise as I thought of it this morning. I'll check my master cylinder reservoir later.
Old Nov 12, 2019 | 01:42 PM
Pipedream's Avatar
Pipedream
To Hiss between shifts
