2002 wiper issuse
Old Nov 7, 2019 | 05:52 PM
Sgillette19's Avatar
Sgillette19
5th Gear
Default 2002 wiper issuse
Hello everyone, I have 2002 and the problem is, when I use my wiper fluid the pump comes on and the wipers move but no fluid comes out, yes it has washer fluid in it. I recently changed the switch because there was a constant humming noise and where u push button in, it was stuck so i replaced the switch. Still no fluid. Any help appreciated. Been looking on here but no success. Thank you for all the help..
Old Nov 7, 2019 | 06:05 PM
johnson-rod's Avatar
johnson-rod
You need to clean the nozzles with a needle. Also check the tubes.
Old Nov 7, 2019 | 06:07 PM
Sgillette19
5th Gear
Will definitely check them out, thank you for the quick response!!
To 2002 wiper issuse
