Electric cooling fan issues
Old Nov 11, 2019 | 10:08 PM
Lil Critter's Avatar
Lil Critter
Default Electric cooling fan issues
My 2001 C5 electric cooling fans seem to be on constantly. Coolant temp is only at 205. Why are the coming on ?
Old Nov 12, 2019 | 12:47 PM
lionelhutz's Avatar
lionelhutz
Is the AC on?
Old Nov 12, 2019 | 01:06 PM
Chillo32's Avatar
Chillo32
Fans will run with ac on. Otherwise, turn off ac and see what temps the low Turns on and the high turns on. I can’t remember the exact temps but do a google search.
Old Nov 12, 2019 | 01:17 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
When you're saying "CONSTANTLY" are you saying the fans run at all times even when the car is first started ??... we need more info !!
Old Nov 12, 2019 | 02:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree.. The AC being ON can cause that issue. (NORMAL) When you turn the ignition switch to RUN (ENGINE OFF), do they come on?
Old Nov 12, 2019 | 08:50 PM
Lil Critter
I usually notice the fans are on after I have been driving a little while. Most noticeable when pulling into a drive thru or when I pull into garage. A/C not always on but fans are. Last night for sure no A/C was on .Coolant temp will be as low as 200-205 but fans do not shut off.
Old Nov 12, 2019 | 10:50 PM
Lil Critter
Ok test drive tonight. Drove about 15 miles to dinner with no A/C. Arrived at restaurant with no fans on.
Drove home with A/C on. Pulled into garage and fan were on high. Turned off A/C , fans stayed on high. Coolant temp 205. Waited 5 min coolant down to 199. Fans stayed on. Turned off car. Waited 1-2 minutes. Started car ... no fans. ?? Outside temp 61*
Old Nov 13, 2019 | 07:26 PM
Lil Critter
So if my fans come on when A/C comes on, why do they stay on even after I turn off A/C ? Is it a pressure related issue on the HVAC system ?
Old Nov 13, 2019 | 08:30 PM
C5 Diag's Avatar
C5 Diag
Do you know your way around a 12 volt test light ??...if so you will have to access the PCM and the high speed cooling fan relay control wire...it is a dark blue wire on pin 33 on the C2 connector...if you turn the AC off and the fans remains on connect the test light to battery POSITIVE...back probe the wire and see if the test light illuminates...if it does the driver in the PCM is sticking closed keeping the circuit grounded...you said the fans were on high speed !!
Old Nov 17, 2019 | 07:42 PM
Lil Critter
Narrowed the problem down to tune that was in the car. The turn on/off temps were way to low. A couple of adjustments on the lap top seems to have taken care of it. Set back to stock temp default. 👍👍
To Electric cooling fan issues
