Pcv "boot" crumbled (2001 car)
Old Nov 18, 2019 | 02:45 PM
Chillo32's Avatar
Chillo32
Default Pcv "boot" crumbled (2001 car)
In the middle of installing a catch can and the pcv boot just crumbled on me. It's a 2001 car with the valve and boot on the passenger side just before the intake manifold.
Interestingly, the "hose" and valve don't connect. Just "meet" inside the boot. I guess the pressure just builds up inside the boot to open and close the valve? I’m wasn’t familiar with the inside workings of that boot.
Wondering if anyone has a “Mcguyver” repair for this and alternatively if anyone has the part number for a new boot (although I doubt it's sold separately). If I need to replace the whole hose etc, does the intake manifold need to come off? The hose runs along the back. Thanks.
Old Nov 18, 2019 | 04:36 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Just used the Dorman part in the link below to fix the same issue.
https://www.corvetteforum.com/forums...be-repair.html
Old Nov 18, 2019 | 05:11 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I’d put an entire new assembly on anyways. Coked up oil over time causes the pcv to fail and pressure buildup makes oil leaks on the oil pan or rear main seals.
I’d spend the $125 on a new hose assembly but not everyone keeps their cars as nice as mine.
Old Nov 18, 2019 | 05:15 PM
Chillo32's Avatar
Chillo32
awesome find. Thank you!!
Old Nov 18, 2019 | 05:16 PM
Chillo32's Avatar
Chillo32
thanks for the advice. So you’re saying that blockage on the pcv line can cause the oil pan gaskets to blow out and leak?
Old Nov 18, 2019 | 05:18 PM
pjdbm's Avatar
pjdbm
I replaced the whole piece when I did my intake.
If that part is deteriorated as such, the other part is probably in similar condition, especially by the Y part of this PVC assembly.
Old Nov 18, 2019 | 05:27 PM
Chillo32's Avatar
Chillo32
thanks. Does the intake need to come off to replace the entire line? It looks like they are loose behind the manifold.
Old Nov 18, 2019 | 05:42 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
FWIW, the car with Dorman part, where we just replaced the boot, has survived 3 hours of track time at Atlanta Motorsport Park doing an HPDE without issue. Josh does have a point so it depends on the condition of your car. If you go all in replace the grommet in the driver's side valve cover as well.
On a 2000, If you have another person to help fish the line, you can put the hoses in place without pulling the intake. One of you pushes the hoses with the other trying to catch the end with their fingers. You could likely do it alone but it might take a few tries. Pulling the intake is not hard but if you do it, and the car has never had it off, I'd replace the injector o rings.
It would be an ideal time to add a good catch can such as Mighty Mouse or Elite.
Old Nov 18, 2019 | 06:08 PM
Chillo32's Avatar
Chillo32
Anyone have any thoughts on the “ground” line aka pcv warm up attachment to the head. Some people say it can be unhooked without problems. Others disagree.
Old Nov 18, 2019 | 08:02 PM
pjdbm's Avatar
pjdbm
You can do it with intake on, snake it through from the passenger side to the driver's side. These have been known to fail and at two spots, one that you currently have.
Good luck
Old Nov 18, 2019 | 08:35 PM
Chillo32's Avatar
Chillo32
Thanks.
Old Nov 18, 2019 | 10:20 PM
helphos's Avatar
helphos
I faced the same issue this summer installing my catch can! I ordered the pcv assembly from Rockauto and just replaced the whole assembly. It was fairly easy to snake behind the manifold without any assistance, and with any luck, I won't have to worry about deteriorated rubber parts in the back of the engine!
Good luck!
Old Nov 18, 2019 | 10:22 PM
Chillo32's Avatar
Chillo32
Good luck!
thanks. Yeah. Just ordered the complete set up from rockauto this evening. What did you do with the heating wire line that attaches to the head/block (can’t remember). I see some people leave it unattached.
Old Nov 18, 2019 | 11:39 PM
helphos's Avatar
helphos
I wrestled with that issue, too. I put it back on, but it didn't go on easy. The catch can caused it to need to be turned funny, but everything's attached now. Why they put that wire on (as a heat conductor!) is a mystery to me.
Old Nov 19, 2019 | 12:04 AM
Chillo32's Avatar
Chillo32
Exactly. That’s how I broke this in the first place, trying to route the catch can hose. I’m guessing g the heating wire is for cold climates. I’m in az so the valve is probably 100 degrees even when the motor is cold.
Old Nov 19, 2019 | 02:11 AM
mbinsat's Avatar
mbinsat
Cruising
4-5 yrs ago that boot fell apart on my 01 Z. I improvised with an old used MSD rubber/silicone spark plug boot-actually it was a dist cap boot (90 degree for a large MSD cap..but a boot for any GM HEI cap will prob work just as well too)-which stretched easily over the pcv valve (2 small wire ties next to each other were perfect to hold it securely on the pcv valve) and the u_shaped pipe slipped snugly into the other end of the boot (where a plug wire used to go in) and everything stays in the exact same place it was before.
Old Nov 19, 2019 | 09:40 AM
wcsinx's Avatar
wcsinx
You really should just replace all the PCV plumbing. All that rubber is vintage '01. The Delco part # is 12590632. That comes with all the plastic tubes, rubber tubes/fittings, and a new valvle.
To Pcv "boot" crumbled (2001 car)
Old Nov 19, 2019 | 09:57 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
If you go with a catch can, you can delete that entire GM hose system and use standard 3/8" hose. I am running the Mighty Mouse 01+ C5 mild routing with a LS2 TB. Driver's side valve cover port is capped. A hose is run from the passenger side valve cover to the TB or in the case of a LS2 TB the coupler between the MAF and TB. The catch can is between the valley cover and vacuum port on the intake.
https://drive.google.com/drive/folde...WRmaW5wODYwU0k
Old Nov 19, 2019 | 10:28 AM
Chillo32's Avatar
Chillo32
Thanks. I am using the Mighty Mouse can, but the guys over there told me to keep the inline pcv valve. I really like the can. But damn that return line runs close to the tensioner. Not sure why they didn’t design it with the inlet and outlet ports a little closer together like the elite engineering can.
I picked up the Dorman boot referenced above as a temporary fix. It actually fits perfectly. A lot more durable than the oem boot.
Old Nov 19, 2019 | 03:07 PM
Chillo32's Avatar
Chillo32
Took off the line that "heats" the pcv. I'm really curious why this is necessary. The pcv is inches from the head anyway. Not sure why the added heat is necessary.
