Corvette turns upon hard acceleration
Old Nov 19, 2019 | 03:44 PM
Thatlighthouse's Avatar
Thatlighthouse
Default Corvette turns upon hard acceleration
I've got an odd thing going on with my C5 base with 36k on the clock. It's a stick. When I accelerate hard on the freeway, it will turn to the left, enough to change lanes if I keep on the gas. The rear end feels kinda "floaty" and odd. I've jacked it up and everything feels tight and I don't see anything obviously wrong with it, but obviously something is going on. I do like to drive the car pretty hard.
Suggestions on what is causing the issue?
Old Nov 19, 2019 | 04:45 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
When was the last time you checked your tire pressures, and/or the car's wheel alignment?
Old Nov 19, 2019 | 05:02 PM
Thatlighthouse
Tire pressure was last week. 30 PSI on all corners.
I've owned the car for 5 months and have not checked the alignment. I've not hit anything hard FYI.
Old Nov 19, 2019 | 05:47 PM
glbeauchamp's Avatar
glbeauchamp
Failing belt on one of the tires?
leadfoot4's Avatar
leadfoot4
OK, has the car always done this?
Old Nov 19, 2019 | 06:43 PM
Chillo32's Avatar
Chillo32
Check the codes. 1287 will jerk the car to the left violently. Otherwise you have an alignment issue or you’re missing your front wheel.
Old Nov 19, 2019 | 06:48 PM
Thatlighthouse
I checked, and I still have both front wheels, lol!
No codes. It's not a violent turning, but enough that it makes the car significantly less fun at speed.
Tires are four months old and in great shape.
I did 3700 miles this summer of "Corvette camping" road tripping, with most of those miles in the mountains and pushing it pretty hard in the corners. I'm wondering if the extra weight (2,000 miles was with a passenger and probably 200-300 pounds of gear) and are cornering pushing something out off whack. That would make sense given the 400# GRV. Thoughts?
Old Nov 19, 2019 | 06:51 PM
Chillo32's Avatar
Chillo32
is your car lowered? Aftermarket wheels? Correct tire sizes? Sway bar bushings ok? Tie rods? End links? All bolts torqued up correctly? Control arms ok? Wheel bearings ok? Shocks ok?
what did you find during a visual inspection of the front suspension?
Old Nov 19, 2019 | 06:53 PM
Thatlighthouse
Stock hight, stock wheels, OEM spec tire size (Michellen PS3). Don't know about the other things.
Old Nov 19, 2019 | 07:12 PM
Chillo32's Avatar
Chillo32
Get the car up on a lift and to an inspection. It could be one of 2 dozen different issues.
Old Nov 20, 2019 | 02:08 AM
Moved to C5 Tech.
Old Nov 20, 2019 | 08:06 AM
leadfoot4's Avatar
leadfoot4
Let me ask, again.....WHEN did this condition start to occur?
Old Nov 20, 2019 | 09:06 AM
Gordy M's Avatar
Gordy M
You might check the right rear camber bolt to make sure it is tight. It sound like the eccentric can shift slightly which would cause excessive right rear camber. This would cause the car to want to pivot to the left.
Old Nov 20, 2019 | 12:32 PM
wydopnthrtl's Avatar
wydopnthrtl
My votes are in order how I'd check:
- bad tire (try swapping rears and see if the problem follows)
- camber bolt slipping / moving under load
- bad ball joint that displaces under load
- Slipping subframe or control arm (maybe a compliance bushing looks good when still. But under a load its allowing too much movement)
- one 1/2 shaft pulling and not the other (very unlikely)
- loose wheel (very unlikely)
Old Nov 20, 2019 | 02:39 PM
jjc508520's Avatar
jjc508520
Mine would dart under acceleration - rear control arm was shot....
Old Nov 20, 2019 | 03:58 PM
dhorner77's Avatar
dhorner77
You said you checked for loose parts...just front or front and rear? My vote based on your description is rear tie rod.
Old Nov 20, 2019 | 04:55 PM
ersatz928's Avatar
ersatz928
Rear tie rod is worn....I had the same issue with my C5.
To Corvette turns upon hard acceleration
Old Nov 20, 2019 | 08:07 PM
davidbeaver's Avatar
davidbeaver
Same here. Had the same issue and replaced outer tie rod ends, ball joints and wheel hubs, then got an alignment. No more darting to the left. I would start with outer tie rod ends and go from there. Of course mine has 130K on it thus the reason for the hubs and ball joints.
Old Nov 21, 2019 | 01:03 AM
NSFW's Avatar
NSFW
Sounds like an alignment problem to me. Maybe something has come loose, or a bushing has worn out and gotten sloppy, or one of the eccentrics has slipped, etc, etc.
Get the car in the air and wiggle the wheels up/down and left/right, to see if anything has loosened up. Take the wheels off, visually inspect the ends of the A-arms, check for bushings that don't line up right anymore.
Old Nov 21, 2019 | 11:11 AM
oharal's Avatar
oharal
Something is most definitely loose. This happened to me once when my driver's side rear lower control arm bolt got loose. Under hard acceleration the control arm would tweak slightly and cause major toe out on that wheel and it would steer the car. Once I found it I tightened it up and never another issue. It's possible your rubber control arm bushings are past their service life and giving too much.
