2001 No DIC no start
- I checked the battery, both voltage and load tested, and it's solid.
- I've had trouble with the BCM in the past, but unplugging it and plugging it back in would usually clear it up.
- I do have an LMC5 installed from a few years ago.
- I installed a new ignition switch about 6 months before I put it in storage
I'm back at my in-laws this week for thanksgiving, so I went ahead and ordered a BCM from Rock Auto to swap out. Similar results with the new BCM:
Edit: This video is slowed wayyy down for some reason
Some things I noticed:
- If I press unlock on the key fob the odometer comes on, but still no button response for the DIC
- Sometimes the dash lights are on, sometimes they're off
At this point I'm thinking I need to pop back out the ignition (I replaced it with a new unit ~1y ago) and check that it's reading the key's resistor correctly, or maybe replace the PCM?
I did replace the power cables running from the battery to the starter and alternator a year or two ago; I was replacing the starter, and the leads to it were corroded to crap, so I went ahead and swapped it out to top post cables, so they should be good.
I pulled a bunch of codes mostly related to things being powered off or disconnected, or me pulling fuses to see if there was anything obvious wrong:
No Codes
TCS
U1000H - Loss of Comms Undetermined
RTD
BCM
B0432HC - Rear Defogger Relay Circuit (I had the fuse out of the HVAC at this time)
B0502H - RH DRL Relay Circuit
B0507H - LH DRL Relay Circuit
B2482H - Backup Lamp Relay Circuit
B2587H - Column Lock/Unlock Drive (A)
B2592H - Column Lock/Unlock Drive (B)
SDM
No Codes
IPC
No Codes
A0-LDCM
B2264H - Vertical Position Sensor Fault
U1064H - Loss of Comms with BCM
A1-RDCM
A6-SCM
No Codes
B0-RFA
B0446 - Right Actuator out of Range
In software we have two stages of development:
- My code doesn't work and I don't know why
- My code works and I don't know why
I'm into that second stage now. Hope it helps someone!
