Stock C5 Cam Failure
Old Dec 21, 2019 | 08:47 AM
MAVetteGuy's Avatar
MAVetteGuy
Thats very possible. Do you know of any way to test the springs so that i can say for sure that was the problem? Id sleep better at night knowing what happened so i i'm sure its fixed and wont happen again. Obviously I'm replacing the springs already so it would be great to know that would solve the problem.
Old Dec 23, 2019 | 08:24 AM
sabastian458's Avatar
sabastian458
This is caused by lifter float, High revs with weak valve springs. I have had 2 engines with the same failure. 1st one a LS6 that had 14 of 16 lobs damaged (Stock engine with a LG can 20k miles on engine, and 2nd one a LS2 with TFS heads, vindicator cam 471hp 40k miles. 11 of 16 damaged.
On the LS6, Ran fine no drivability issues until randomly one day at idle I lost oil pressure. Raise rpms to 1500-1800 and it would return. I was about 35 miles from home and drove it back. Tear down found lobe damage. No lifter was turn 90 degrees, there was never any abnormal noise from the engine other than slightly louder ticking from the engine at idle when no oil pressure.
on the LS2, I only found the issue when I pulled he heads to send off to get ported. Zero drivability issues, zero issues with oil pressure.
Both engines only ever lived on Mobil1 oil or amsoil every 4500-5000 miles with a Wix filter.
i replace valve springs every 18 months or 10k miles on any of the LS engines i work on as preventive maintance and haven’t had the issue since.
Old Dec 24, 2019 | 07:49 AM
vettenuts's Avatar
vettenuts
If you are going with a stock cam, upgrade the springs to the LS6 springs for an LS1 cam. If it were me, I would go with the PSI1511ML valve springs and shim them for 135 lbs on the seat. These are excellent long life endurance valve springs.
Old Dec 24, 2019 | 08:43 AM
MAVetteGuy's Avatar
MAVetteGuy
I'll be installing a Tick Performance SNS Torquemax camshaft package that comes with dual valve springs that Tick has speced for that cam.
Old Mar 13, 2021 | 02:15 AM
Ins18's Avatar
Ins18
5th Gear
did you have to rebuild your motor when this occurred?
Old Mar 13, 2021 | 06:34 AM
MAVetteGuy's Avatar
MAVetteGuy
Sure did Ins18
https://www.corvetteforum.com/forums...e-rebuild.html
Old Mar 13, 2021 | 02:50 PM
grinder11's Avatar
grinder11
I hope you go with something other than stock, 'while you're in there'. BTW......GM had some issues around that time with improperly heat treated cams, and this happened to some people who never overrevved or floated their valves......
Old Mar 14, 2021 | 09:46 AM
MAVetteGuy's Avatar
MAVetteGuy
That honestly makes me feel a lot better. For the life of me i couldn't determine the cause of the damage. A poor quality part would explain a lot.
And yes the current state of the car is far from and much better than stock.
