2001 Electrical question
Old Dec 6, 2019 | 10:51 PM
Moenman1's Avatar
Moenman1
Navigator
Default 2001 Electrical question
Can anyone explain to me how I get the lights on my switches right side of Dash to shut off when my car is off.. it seems that these lights stay on always and I can’t figure out how to shut them off..
thanks
Old Dec 6, 2019 | 11:23 PM
Moved to C5 Tech.
Old Dec 6, 2019 | 11:32 PM
STRMLNE's Avatar
STRMLNE
What switches are you taking about?
Old Dec 6, 2019 | 11:51 PM
Moenman1's Avatar
Moenman1
Navigator
sorry I should have been more clear.. the DIC buttons as well as the heads up display panel.. it seems that the back light is on and I can figure out how to shut them off..
no other interior lights are on
thanks
Moenman1's Avatar
Moenman1
Navigator
Old Dec 7, 2019 | 08:59 AM
rrwirsi's Avatar
rrwirsi
If you have an owners manual, look under the heading, "Interior Lamps"
Here is what my '04 manual says:
Interior Lamps
Instrument Panel Brightness
The **** for this feature is
located on the left side of
the instrument panel.
Push the **** to release it from the stored position.
Turn the **** clockwise to brighten the lights or
counterclockwise to dim them.
Be sure not to have this **** turned all the way down
with the lamps on during the day. Your Driver
Information Center (DIC) may not be visible.
Parade Mode
The instrument panel brightness **** has an added
feature called parade mode to assist you in seeing
certain instrument panel controls if your headlamps are
on in the daylight. Turn the **** counterclockwise to
dim the instrument panel lights or clockwise to brighten
the lights. This will occur only with the parking lamps
or headlamps on.
Courtesy Lamps
When any door or the hatch/trunk lid is opened, the
interior lamps will go on unless it is bright outside.
You can also turn on the courtesy lamps by turning the
instrument panel brightness **** all the way clockwise.
Exit/Entry Lighting
With entry lighting, the interior lamps will come on when
entering the vehicle. The interior lamps will come on
for about 20 seconds when the key is turned to OFF or
a door is ajar.
You can turn exit and entry lighting off by quickly turning
the headlamps on and off or by quickly turning the
courtesy lamps on and off.
Old Dec 7, 2019 | 09:08 AM
Moenman1's Avatar
Moenman1
Navigator
Default DIC lights
Interior Lamps
Parade Mode
or headlamps on.
Courtesy Lamps
Exit/Entry Lighting
a door is ajar.
I do have a manual and have read it read it over and over.. what baffles me is that these lights are on when the car is off? I’ve followed all of the steps above as it seems the 01 and 05 manual say the same thing.
Old Dec 7, 2019 | 04:33 PM
Moenman1's Avatar
Moenman1
Navigator
Default 2001 DIC Lights that stay on when car is off
thanks
all I wanted to let you know.. that my issue seemed to be a simple fix. I disconnected the Negative side on the battery, let it sit for 5 mins or so, Hooked it back up and it resolved my problem.. not sure if there might have been a glitch in a circuit.. Hope this helps someone in the future
Old Dec 7, 2019 | 05:13 PM
STRMLNE's Avatar
STRMLNE
The backlights on mine seem to go out after about 20 seconds.
To 2001 Electrical question
