Oil drain bolt stuck
Old Dec 12, 2019 | 01:27 PM
Crosis's Avatar
Crosis
Default Oil drain bolt stuck
i went to change my oil today and the 15mm drain bolt just won’t break loose. I am afraid to really throw some torque on it because I feel that could break it off or damage the pan. Is this possible? Any suggestions?
Old Dec 12, 2019 | 01:48 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Somebody clearly over-torqued it last time.
Your best approach is to use a box end wrench and hit it with a 1# hammer on the other end. The shock of the hammer blows should break it loose without actually breaking the bolt. Start with light blows and work you way up until it breaks loose.
Oh, and don't hit your hand with the hammer.
Old Dec 12, 2019 | 02:31 PM
johnson-rod's Avatar
johnson-rod
Be very sure you are actually UNLOOSENING the bolt. Righty tighty - Lefty loosey.
A friend and I spent hours trying to get a spark plug out of some lady's 390ci Ford. It wouldn't budge. We eventually found we were tightening it not loosening it. We both got turned around because of how hard it was to get to the plug and how cranked around we were and how little force (luckily) we were able to put on the plug in that position. I don't remember why or how we discovered our error. We just shrugged and got on with the rest of the tune-up. Set your ratchet BEFORE you crawl under and start banging.
Old Dec 12, 2019 | 05:43 PM
Crosis's Avatar
Crosis
I actually was able to get a ratchet wrench on it and of course it was set to loosen and not a budge. The stealership must have used loctite red on the thing.
note... unloosening is the same as tightening.
Old Dec 12, 2019 | 05:55 PM
knewblewkorvette's Avatar
knewblewkorvette
Call this guy at 867-5309
On a serious side, I would try what 4XLR8N said.
Old Dec 12, 2019 | 06:13 PM
FX VETTE's Avatar
FX VETTE
actually, that's Jenny's #
Old Dec 12, 2019 | 06:25 PM
knewblewkorvette
That guy is Jenny's boyfriend
Old Dec 12, 2019 | 06:34 PM
Grandpa1's Avatar
Grandpa1
I think he only works on watches.
Over the years I have had to take a small pipe wrench or a good pair of vice grips to take off a drain plug it it gets rounded off.
If you can't break it loose with a regular box in or 6 point socket you may need to try it.
I have never seen or heard of one that twisted off and left the thread in the hole.
Just use some strength and get it done!
Good luck!
Old Dec 12, 2019 | 06:36 PM
FX VETTE's Avatar
FX VETTE
Old Dec 12, 2019 | 06:40 PM
FX VETTE's Avatar
FX VETTE
Crosis, have you given it a dose or two of PB Blaster?
Old Dec 12, 2019 | 09:03 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Usually when something like a drain plug gets stuck it needs shock more so than torque.
Get yourself and impact and it will come right off. If you don't want to do that, then as suggested hit your wrench with a hammer.
Old Dec 13, 2019 | 12:11 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Hit it with your purse.
I'm just kidding. Make sure you use a 6 sided wrench. You can link two wrenches together two amplify your torque. That's probably your best bet. Getting the oil good and hot is probably a good idea. If the drain plug is that tight, chances are the filter is tighter than a sumbitch too. Getting everything good and hot first is your best bet to get both off.
Old Dec 13, 2019 | 08:40 AM
Crosis's Avatar
Crosis
not yet. It’s got an oily residue on it so it’s pretty lubed already.
Old Dec 13, 2019 | 08:41 AM
Clancy209's Avatar
Clancy209
oil pan w/ plug is a cheap investment
Old Dec 13, 2019 | 09:01 AM
vinceg's Avatar
vinceg
Get the engine good and HOT the warm oil in the aluminum oil pan will expand slightly this will help.
Old Dec 13, 2019 | 10:42 AM
glbeauchamp's Avatar
glbeauchamp
When you get to the filter, get up as close to the top as you can with the filter wrench. If it is on really tight you may end crushing the filter and then you got problems. Don't ask how I know this.
Old Dec 13, 2019 | 10:52 AM
Crosis's Avatar
Crosis
yeah, it’s not like it’s the engine block. It’s replaceable.
To Oil drain bolt stuck
Old Dec 13, 2019 | 12:15 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
I had to use an air chisel to get mine off at my last oil change.
Zipped it off in a few seconds.
Old Dec 13, 2019 | 01:40 PM
Ron Miller's Avatar
Ron Miller
That's the best solution. Start with the impact set low, gradually increase the amount until it moves. It'll give . . . . . .
Old Dec 14, 2019 | 12:53 AM
Moved to C5 Tech.
