Skip Shift Solenoid Leak
Old Dec 13, 2019 | 08:00 PM
azvrod's Avatar
azvrod
Default Skip Shift Solenoid Leak-Advice needed
Hey all, looks like Ive got a trans fluid leak from the skip shift solenoid. I understand that there is a small O ring and its probably given up the ghost. Its just a very small drip, but still would like to fix it. It looks like its really hard to get up in there to remove the solenoid. Any adivice on whats involved? Do I need to drop the cradle, etc. or is it doable with the correct angle and wrench (really big and short)? Thanks for any help!
Old Dec 15, 2019 | 02:48 PM
azvrod's Avatar
azvrod
Anyone?
Old Dec 17, 2019 | 08:50 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I replaced my reverse lockout solenoid it was on the top of the transmission. Not a hard job. The skip shift solenoid is on the driver's side of the transmission and if I am remembering correctly was easier to get to. Not sure what size socket you need to get it off. You can buy the seal and just replace it.
Old Dec 18, 2019 | 11:48 AM
azvrod's Avatar
azvrod
Thanks man, Im going to put it back up on the lift and see how hard it is to reach. I bought a 33mm crows foot wrench to see if that helps with the clearance issues. Just dont want to drop the carriage if I dont have to..
To Skip Shift Solenoid Leak
