Bent/broken flexplate ?
Old Dec 15, 2019 | 11:05 PM
Electron447's Avatar
Electron447
Default Bent/broken flexplate ?
Good day all! Today I have some questions that bamboozle me bc I’ve never seen anything like this in all my years of study mechanics and working on cars. But first a little back story.
a couple months ago* : I was driving down the highway doing about,eh, 75-80mph . Cars were entering the highway ,I blipped the throttle to speed up a tad bc I could get over. Well I pass the entering cars and decide to blip the throttle,nothing to harsh. And I all of a sudden ,I get no movment. Engine is still running,transmission is still engaging but no forward movement. I’m coasting by this time.t first thought was that,oh no .. the trans took a S***... turns out it didn’t. Then I thought timing ! But engine still ran until I turned it off ! Then I thought starter . But it’s perfect. Long story short ,I dismantled the engined and timing was good. Basically what id
like to ask is “ HOW THE HECK DID THIS HAPPEN “ any and all input is appreciated and welcome . Car is fully built .
447 stroker, driveline build from RPM. Below is a pic of what the inside of the bellhousing looks like.
Old Dec 15, 2019 | 11:09 PM
USAZR1's Avatar
USAZR1
https://www.corvetteforum.com/forums/c5-tech-1/
Old Dec 16, 2019 | 10:11 AM
Moved to C5 Tech.
Old Dec 16, 2019 | 10:51 AM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I have one if you need it,where are you located?
Old Dec 16, 2019 | 11:04 AM
Electron447
Im not sure if this one will hold up ... idk how it even came to break like this .
also I’m in Michigan.
Old Dec 16, 2019 | 11:59 AM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Better off with one like this,I don't have a full pic but this is in my car
Old Dec 16, 2019 | 02:11 PM
Electron447
where did you order and what was the price for plate(s)?
Old Dec 16, 2019 | 02:38 PM
feeder82's Avatar
feeder82
RPM transmissions sells one $349.
Old Dec 16, 2019 | 05:02 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
I think that's where I got mine from RPM,well worth it
To Bent/broken flexplate ?
