Throttle Response Question or Help
Old Nov 17, 2002 | 11:42 AM
Kenny94945's Avatar
Kenny94945
Default Throttle Response Question or Help
Hi all,
My C5 A4, which I shift like a manuel, feels "fat" when I blip the throttle from second to first around 2500 rpms (especially). Third to second can be fat sometimes.
At upper rpms everything sings.
I have only one dyno and air/ fuel print out.
Here in the San Francisco Bay Area, I am kind of waiting around on the LS1 edit notion and hesitant to spend quality time fooling around.
My assumption is it is either too much air...or not enough. Temperature and humidity do not make a difference...problem is constant rain or shine.
So..
1) Would an aftermarket airbridge help with the "fat".
2) Would only smoothing (polishing to mirror finish) the air filter side of the throttle body help with throttle response. (Dremel tool is ready).
3) Would the MAF translator be a tuning tool that will cure this? If so any of my fellow co-member in the area experienced with this tool and "up" for a mod party?
To recap... Low rpm throttle response sucks.
Please offer any wisdom.
Kenny
Old Nov 18, 2002 | 12:11 AM
Duck916's Avatar
Duck916
Default Re: Throttle Response Question or Help (Kenny94945)
Can you be a little more specific about the problem? I'm not sure what you mean by "fat."
Also, am I reading this correctly, that you are experiencing this problem when blipping the throttle as you shift from second to first? Sorta like you'd do with a manual transmission to match revs?
Old Nov 18, 2002 | 12:39 AM
DsC5's Avatar
DsC5
Default Re: Throttle Response Question or Help (Duck916)
:confused:
Old Nov 18, 2002 | 11:28 AM
Kenny94945's Avatar
Kenny94945
Thanks for asking for more info.
Yes...blipping the throttle; matching revs.
"fat"...in my opinion too much fuel. Not a sharp rpm acceration. More of a lazy accelaration of rpms.
Old Nov 18, 2002 | 12:09 PM
Mike Mercury's Avatar
Mike Mercury
hmmmmm... torque management?
there was rumored to be a major re-write of the TM software in 2001; and a small enhancement in 2002; keeping it from intruding in situations where it shouldn't be limiting.
[Modified by Mike Mercury, 12:12 PM 11/18/2002]
Old Nov 18, 2002 | 01:05 PM
jawski's Avatar
jawski
Default Re: Throttle Response Question or Help (Mike Mercury)
how about an unlocked torque converter?
MAFT works well for me at part throttle
Old Nov 18, 2002 | 05:22 PM
Kenny94945's Avatar
Kenny94945
um...torque management...
At least for me, when I move the shifter from 3rd to 2nd and from 2nd to first there is a monmetary neutral in which I can blip the throttle and the rpm build without jerking the car.
Anyone else's A4 feel/ notice this.
Also, below 2000 rpm is more of a "fat" than 2500 rpm.
So, I guess my question would be do you all think the car is running rich or lean around 2000 rpm.
Maybe a LS1 edit is called for. oh my.
Old Nov 18, 2002 | 06:25 PM
Killrwheels's Avatar
Killrwheels
contact Bfb and get the Diablosport Predator. It's biggest strength .......it quickens the shift between gears (dull spot) and you can even extend the shift RPM on WOT to allow more "fat ??" and as a bonus will bring you further into the REV on next gear......
http://www.runninwiththedevil.com/predator.htm
[Modified by Killrwheels, 6:31 PM 11/18/2002]
To Throttle Response Question or Help
