Electrical issues strike
Could I try a paper clip?
Here is what happens with LT and DK green jumped. and the bar removed on both packs. Basically the same as with the bar installed on both packs. Without the jumper it would not start at all.
Here is the result with both bars installed after the above video.
When the car does start it is running really rich. Bad fumes in the garage.
I am thinking it could be 2 separate issues. Here is a thread with the brake issues...https://www.corvetteforum.com/forums...ake-pedal.html
I talked to LMC5 today. Great people. They basically ruled out column lock or ignition issues.
I did a little more recon. Looking at my home surveillance I did have reverse lights when leaving the house. No evidence of brake lights but I might not have used the brakes.
Now, I do not have reverse lights. In fact, putting the car in reverse now turns on the dash lights. Same and the brakes.
This makes me think the light issues and rough run and die are related since I had reverse lights when leaving and then everything went crazy about 3 blocks away.
As luck would have it bulbs in both my test lights are broken. Although one worked for a split second before going out.
No reverse lights at all. When I put the key in I hear a sound that I would best describe as dry sucking sound. Not what I would typically expect from a pump when turning the key to accessory.
B2578- RF turn signal monitor circuit
B2583- LF turn signal monitor circuit
U1064- Loss of comm BCM
U1096- Loss of comm IPC
U1255 serial data malfunction
U1000- loss of comm
Cleared all
Started car...run only if I gave it gas. Very rough and smelly. Ran about 20 seconds.
Only code to reappear was B0-RFA U1064 H- Loss of comm BCM
This is from '99. I'm not sure if '01 has any variations, but since you have the FSMs you can easily make adjustments if needed. Using a multimeter, check both testing points on the upper edge of the following fuses:
A) FUSE 9 - Hot in ACC and ON
B) FUSE 13 - Hot in ON, Bulb Test and START
C) FUSE 22 - Hot in ON
D) FUSE 23 - Hot at all times
E) FUSE 25 - Hot at all times
If the fuses test OK, then backprobe the corresponding pins in the BCM connectors to make sure power is getting to them:
A) Connector C2, Pin D12 (from FUSE 9 - Hot in ACC and ON)
B) Connector C2, Pin D13 (from FUSE 13 - Hot in ON, Bulb Test and START)
C) Connector C1, Pin B11 (from FUSE 22 - Hot in ON)
D) Connector C3, Pin A4 (from FUSE 23 - Hot at all times)
E) Connector C1, Pin A4 (from FUSE 25 - Hot at all times)
Also backprobe the following pins with ignition in OFF to check continuity to ground (they should read 0 Ohms to ground):
A) Connector C1, Pin A9 - Grounded at Ground Point G104
B) Connector C3, Pin A2 - Grounded at Ground Point G202
Let us know how it goes
Respliced wires and have not had any problems in 4 years since.
Mice love the taste of the plastic covering that the automotive industry now uses.
Good Luck and please post when you find and fix problem.
Can you guys tell me want your fuel pump sounds like when the key is turned to on? This video shows the dry sucking sound I mentioned. I don't think it is getting fuel but have not had time to test more yet.
Recap of fuel relay-
Pin 87- tested good
Pin 86- tested good - 11.95 residual with multi meter
Pin 30- Ground tested good
Pin 85- Ground tested good
Note- That odd sound on the pump is not present with the rely removed, so that sound must be the pump.
Big area of concern is in the video. I see no visible wire issues under the under or around the PCM. Check out the video of the cowl area. This has to be from mice but I am not sure where to go next.
How hard is it to test power at the fuel pump?
