C6 leaf spring on a C5
Old Dec 26, 2019 | 06:30 PM
EZ2BEVILC5's Avatar
EZ2BEVILC5
Default C6 leaf spring on a C5
Hello,
I wanted to confirm we can use C6 leaf springs on our C5's. Do any modifications need to be done.
Also, what are the benefits of using a C6 Z06 leaf spring compared to a C5 Z06 spring.
I am looking to replace the front spring. Any feedback is appreciated.
Thank you
Old Dec 26, 2019 | 11:26 PM
Moved to C5 Tech.
Old Dec 27, 2019 | 12:01 AM
pjdbm's Avatar
pjdbm
The rear spring is different for sure on the C6, I did this a few years ago and end up using C5z springs on front & back.
Old Dec 27, 2019 | 09:00 AM
StickTail's Avatar
StickTail
This should be a sticky.
https://www.corvetteforum.com/forums...at-fit-c5.html
Old Dec 27, 2019 | 10:57 AM
scorpiofox69's Avatar
scorpiofox69
Keep in mind that suspension geometry/ratios must be kept relatively proportionate to spec in order to prevent understeer/oversteer concerns.
I assembled the following for my car and it handles very well for a Vert:
C6 base wheels (I am not going to disclose my tire choice as your thread will get hijacked)
C6 Z06 shocks (AC Delco)
C6 Z51 front spring
C5 Z51 rear spring
C5 Z06 front sway bar
C6 Z51 rear sway bar
Poly bushings
Old Feb 23, 2021 | 05:04 PM
davidfarmer's Avatar
davidfarmer
Get the car in the air, use a jack to life the spring up off of the control arm..PB Blast the adjuster and get a good closed end wrench-socket on it. They do get tight, but generally if you unload and lubricate them you can make it turn without damage.
To C6 leaf spring on a C5
