As a follow up:
Went to the local tire shop and they got them recognized. Only cost me 2 6 packs in Cantuckee speak, that converts to a little over $12 in Dairy Country.
So I'm looking to replace my tire sensors. Which one is the best and easiest to setup using my magnet to set them up with.
It's for a 2002 corvette
I bought the OEM type Schraders for mine. Took a couple minutes to set up with a magnet. I bought them from Rock Auto.
I bought mine from Amazon ($45) just search for #25773946. Installed them myself by breaking the bead using a 2x4 and a short piece of 1x6. Just could not get the computer to learn them with a magnet. Had to go to a tire shop to get the TPMS recognized cost was about $13 for all four. I'm starting to believe that my magnet may have not provided the necessary gauss (power) to trigger the learning...
FYI, others got theirs to be recognized using a magnet
Did a lot of research for my 98 which has much more expensive TPMS and found a site called TPMS 24/7.com.
they were only $100 for set and perform perfectly.
