TPMS issues C5
Old Dec 27, 2019 | 02:48 PM
Ronnieg2001's Avatar
Ronnieg2001
6th Gear
Default TPMS issues C5
Hey guys.
just put new wheels/tires/tpms on my 01 C5. Cannot get the sensors to communicate to car. stored old wheels with old tpms in attic, was 5 miles away and car was still reading 0psi!! any suggestions?
thanks
Ronnie
Old Dec 27, 2019 | 03:06 PM
rat123's Avatar
rat123
Did you do the sensor setup
Using magnet
Old Dec 27, 2019 | 04:01 PM
JR-01's Avatar
JR-01
Did you do this?
Reprogramming the sensors requires a strong (preferably u-shaped or circular) magnet.
1. Turn the key to the ON position but do not start the car.
2. Press the DIC RESET button to clear any warning messages, if they’re present.
3. Press the OPTIONS button and cycle through the menu until the display goes blank.
4. Press and hold the RESET button until “FOB TRAINING” appears on the display.
5. Press the OPTIONS button once. A “TIRE TRAINING” message is displayed.
6. Press the RESET button once. A “LEARN LEFT FRONT TIRE” message is displayed.
7. Hold a magnet over the Valve Stem on left front wheel. You may have to move it around the valve stem to hit the right spot.
8. When the horn beeps (about 7 seconds later), programming is complete for THAT wheel.
9. Program the other 3 wheel sensors as directed by the DIC message display. The sequence is as follows: Left Front, Right Front, Right Rear, Left Rear.
You have approximately 45 seconds to train each tire. If the sensor isn’t reset in that time, the training program shuts down and you will have to start the entire procedure over.
Old Dec 27, 2019 | 06:03 PM
Ronnieg2001
6th Gear
yes i did all of that with powerful magnet and vette didn't respond and timed out.
Old Dec 27, 2019 | 06:12 PM
JR-01's Avatar
JR-01
Are the new TPMS OEM Schraders?
Old Dec 27, 2019 | 06:15 PM
_zebra's Avatar
_zebra
and did you get the correct sensors? 01-04 use different ones than 97-00.
Old Dec 27, 2019 | 07:43 PM
Ronnieg2001
6th Gear
This is the tpms i used.
Old Dec 27, 2019 | 08:05 PM
JR-01's Avatar
JR-01
Those may have to be programmed with an electronic training tool. Your local tire shop should have one.
Old Dec 27, 2019 | 10:22 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
^^^YES^^^ This, I installed aftermarket sensors on my new wheels and you will have to get them programmed with a reader. The magnet won't work. Also, my new sensors don't read any pressure until after the car/wheels are in motion. So forget about reading them before a trip with just the key on. Other then that they've worked out great. Good luck with yours.
Old Dec 27, 2019 | 10:54 PM
Moved to C5 Tech.
Old Dec 28, 2019 | 12:41 AM
_zebra's Avatar
_zebra
Originally Posted by mstromquist
...Also, my new sensors don't read any pressure until after the car/wheels are in motion. So forget about reading them before a trip with just the key on. Other then that they've worked out great. Good luck with yours.
that's because centrifugal force is what activates their power & transmitters.
Old Dec 28, 2019 | 12:17 PM
mstromquist
That is true and I understand how they work, but my old original shrader ones would display the pressure before moving the car. These don't do that.
Old Dec 28, 2019 | 01:08 PM
OLDMAN C-5's Avatar
OLDMAN C-5
7th Gear
I have one wheel on my 99 coupe does the same thing. LF wheel reads flat tire at start up then as I drive pressure comes up on DIC. But still reads about three pounds low.Confused in FLA
Old Dec 28, 2019 | 05:14 PM
rat123's Avatar
rat123
What is the best TPMS for a 2002 corvette
Old Dec 28, 2019 | 05:21 PM
Rick369's Avatar
Rick369
Schrader or AC Delco. Schrader makes the AC Delco brand TMPS sensors.
Old Dec 31, 2019 | 09:26 AM
Ronnieg2001
6th Gear
Thanks all. once i get to tire shop, i will give result.
Happy New Year
Old Feb 12, 2020 | 01:22 PM
I.B.Sorgn's Avatar
I.B.Sorgn
Interesting thead. Changed all my old TPMS (Schraders) for AC Delco (#25773946) just a few days ago and could not get the system to acknowledge them with the magnet procedure. So if I'm following this thread correctly some TPMS must use the electronic training tool? And those TPMSs are the AC Delcos?.
Had a message come up on the DIC that stated Left front was flat and speed will be limited to 55mph. That was after I had pulled the valve stem out of the tire. Have not seen that message today..
To TPMS issues C5
Old Feb 12, 2020 | 05:34 PM
JR-01's Avatar
JR-01
Was that the correct part number for your year C5?
Old Feb 13, 2020 | 09:04 PM
I.B.Sorgn's Avatar
I.B.Sorgn
The internet showed the Delco's as a replacement OEM unit
Old Feb 13, 2020 | 09:08 PM
JR-01's Avatar
JR-01
Then it should work the same as the original. That part number shows it will not work in my '01.
