Turn Signs and running lights
Old Jan 14, 2020 | 07:19 PM
thevelvetglove's Avatar
thevelvetglove
Default Turn Signs and running lights
c5 CORVETTE 2000, 148K
I would like my orange front running light/ turn signals to stay on, and then blink when I signall to turn. I just had a garage upgrade my turn signal wiring as it was getting old and my front turn signals only blink, then go off and do not stay on. The turn signal only lights up when I use the turn signal and then goes off?
How can I get them back to how I had them before.
Old Jan 15, 2020 | 11:19 AM
GCG's Avatar
GCG
Originally Posted by thevelvetglove
...I just had a garage upgrade my turn signal wiring as it was getting old...
What do you mean by that? What did they do?
Old Jan 16, 2020 | 02:13 AM
thevelvetglove
Ok thanks for the feed back, let me try again.
Before they rewired my front lights, the front directional blinker worked in two modes. If I was not using them to signal I was turning left or right, they would simply stay on as my running lights.
So, after the rewireing, they only function as Directionals blinkers and do not operate as running lights when not in use as directionals. How do I fix this.
Old Jan 16, 2020 | 09:29 PM
3sACROWD's Avatar
3sACROWD
I suspect you have a blown fuse. I'm not near my car so can't look at the owner's manual. Maybe someone else can chime in.
Old Jan 16, 2020 | 09:30 PM
3sACROWD's Avatar
3sACROWD
Forgot to mention they are called Daytime Running Lights - DRL.
Old Jan 17, 2020 | 09:25 AM
OregonDan's Avatar
OregonDan
I'd go back to that garage and have them wire it the way it was! They changed something...
Old Jan 19, 2020 | 09:05 AM
thevelvetglove
ThAnks everyone, think I will take it back to the garage after I check the fuse
To Turn Signs and running lights
