What's the part# for the backup light switch?
Old Nov 18, 2002 | 07:27 PM
6500RPM's Avatar
6500RPM
Default What's the part# for the backup light switch?
My backup lights keep going out and I was told that it might be the switch. Does anyone have the part#? Thanks in advance.
Old Nov 18, 2002 | 10:54 PM
alc2001's Avatar
alc2001
Default Re: What's the part# for the backup light switch? (6500RPM)
Jesse - Buckup Lamp Switch part # is 14069600. The switch is located on the passenger side of the MN6 and the service manual says to remove the catalytic convertor (H-pipe) to replace the switch. Hopefully you can get at it without having to remove the exhaust. Be sure to check the B/U lamp relay under the hood first. That part number is 12077866. Hope this helps.
Alan :seeya
[Modified by alc2001, 7:54 PM 11/18/2002]
Old Nov 18, 2002 | 11:06 PM
6500RPM's Avatar
6500RPM
Default Re: What's the part# for the backup light switch? (alc2001)
Thanks Alan! :cheers: :cheers:
To What's the part# for the backup light switch?
