Trans is toast?
Changing the fluid and filter on a C5 A4 is fairly easy, but there are specific procedures to insure that the fluid level is correct after the change:
After replacing the filter and bolting the pan back up, fill with new fluid to the drain/ check level plug hole. Then start the engine and leave it running with the transmission in PARK.
Immediately add fluid through the drain/ check level plug hole until fluid flows out of the plug hole. It may take as much as another couple of quarts.
With your foot holding the brakes, cycle the transmission through all the gears, then back to PARK.
Go back underneath and make sure that fluid is still dribbling out of the fill/ check level plug hole. You might have to add some.
With the engine still running and the transmission in PARK, monitor transmission temperature on the DIC. Keep a pan under the open fill hole, fluid will dribble out as the transmission warms. When transmission temperature rises to 122 F, put the plug in the fill/ Check level hole.
Do NOT shut the engine down until the plug is in the fill/ check level hole. If you do, HOT fluid will gush out and the transmission will be low on fluid.
I recommend full synthetic fluid.
Keep in mind that the above procedure drains about half the fluid in the A4. The other half is in the torque converter and other works.
You will need a small hand pump to pump the fluid into the fill/ check level hole.
