stalling
Old Jan 24, 2020 | 11:35 AM
joey321's Avatar
joey321
Cruising
Default stalling
problem: after warmup, engine throttle hesitation and stalling when coming to a stop. have had 2 shops look at it with
no results. any ideas? thanks jmc@ryco-cpa.com
Old Jan 24, 2020 | 07:28 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
I'm sure people can make some wild guesses but it would help to have a little more info. Is the car modded? If so what has been done? How many miles? Have you pulled the codes?
When you offer up a symptom that is so generic, the generic response you're going to get is, yep, something is wrong.
Old Jan 24, 2020 | 07:30 PM
K-Spaz's Avatar
K-Spaz
Check and see if any of the intake bolts have come loose. Whatever you do, do not over tighten them. With a tiny quarter inch drive ratchet you can use fingertip pressure and that is it. I believe it's an 8 millimeter socket and there are 10 bolts. If there's a vacuum leak that will definitely give you problems.
To stalling
