ARE LS6 NEW PORT!
Old Nov 19, 2002 | 12:35 PM
AREC5's Avatar
AREC5
Default ARE LS6 NEW PORT!
Here is some pics of our new LS6 port design!
http://www.agostino-racing.com/hidden.asp
We thought you all might like to see the quality workmanship of our new LS6 port design.
These heads have 2.055 intake valves & 1.57 exhaust valves and use a 8mm stem (light weight)
The heads without a stack flow the following:
LIFT INT EXH
200 138 114
300 205 157
350 234 175
400 262 194
450 284 202
500 297 210
550 314 216
600 321 220
We will be posting our 6.0L Forced Induction & LS1 head pics & results soon...
Old Nov 19, 2002 | 03:00 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: ARE LS6 NEW PORT! (AREC5)
Wow those look sweet Wade..
Here are the pics at this link:
[Modified by MattG, 3:02 PM 11/19/2002]
Old Nov 19, 2002 | 07:58 PM
Slammed Vette's Avatar
Slammed Vette
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: ARE LS6 NEW PORT! (MattG)
Talked with Matt already!!!Getting a set of these in Stage III for my car!!!!!
Old Nov 19, 2002 | 09:01 PM
stroked382ciTransAm's Avatar
stroked382ciTransAm
how much are those heads outright with core charge and what is the wait time on those
Old Nov 20, 2002 | 04:07 AM
blktie8's Avatar
blktie8
ttt
Old Nov 20, 2002 | 07:18 AM
Bowtie8's Avatar
Bowtie8
Default Re: ARE LS6 NEW PORT! (blktie8)
How about milling? Where are they starting out at? What cc
What is the intake port volume after porting?
Also, will ARE settup the springs to our specs, and what brand?
What diameter of spring?
John
Old Nov 20, 2002 | 09:36 AM
MattG's Avatar
MattG
Default Re: ARE LS6 NEW PORT! (stroked382ciTransAm)
With our limited time special pricing from this post: http://forums.corvetteforum.com/zerothread?id=414225 you would be looking at $1900 for Stage 1 or $2300 for Stage 2 and then a $1400 core charge for the LS6 castings. If you can find LS6 castings for a lower price, you can always send them to us to have them done.
We have LS1 heads in stock and ready to go, and for LS6 heads, you would probably be looking at a 2-3 week build time.
Email me if you need any more info or if you decide you want to order a set.
Old Nov 20, 2002 | 09:40 AM
MattG's Avatar
MattG
Default Re: ARE LS6 NEW PORT! (Bowtie8)
Head milling is included in the price of the heads if you decide you want it done.. On a set of LS6 heads milled .030 you would be looking around 11.25 CR. On a set of LS1 heads milled .030 you would be looking around 10.80 CR.
The intake volume on these heads that were done for a heads/cam appliction is right around 230cc. If these heads were done for a larger displacement motor with a cam over 0.600 lift, the intake volume would be increased.
ARE will setup the springs to whatever specs you want. Spring selection would depend on how you want them to be setup.. ARE currently uses Comp Cam 918 Springs in their Stage 1's and REV 1.250" Duals in their Stage 2s and Manley 1.450" Duals in their Stage 3s.
Let me know if there are any more questions.
[Modified by MattG, 10:00 AM 11/20/2002]
Old Nov 20, 2002 | 09:56 AM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In IV Veteran
I have a question...did you mean to say Ls1 heads milled .030 will be looking at around 10.80 CR?
Head milling is included in the price of the heads if you decide you want it done.. On a set of LS6 heads milled .030 you would be looking around 11.25 CR. On a set of LS6 heads milled .030 you would be looking around 10.80 CR.
[Modified by Flyin'Brian, 9:19 AM 11/20/2002]
Old Nov 20, 2002 | 10:01 AM
MattG's Avatar
MattG
Default Re: ARE LS6 NEW PORT! (Flyin'Brian)
You are correct! My Bad! :) I corrected the typo in my reply above.
By the way, you have mail!
[Modified by MattG, 10:03 AM 11/20/2002]
Old Nov 20, 2002 | 07:59 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
They sure are pretty! Great #s BTW.
MattG- what is the stock LS6 intake port volume?Thanks. :cool: :cool: :cheers:
To ARE LS6 NEW PORT!
