What's the trick to remove headlight wire connector on C5 from fender apron?
In order to make things easier, park your car turning the steering wheel all the way to the side you are going to be working on, so you can reach with your hand the fender apron's underside.
While holding the connector with one hand, use your other hand (in the wheel well side) to locate the connector anchor that was inserted through a hole in the fender apron. You will then need to compress the anchor's legs to be able to pull it up and free the connector.
