Z51 shocks vrs. stock
Old Nov 19, 2002 | 06:22 PM
WikdC5's Avatar
WikdC5
Default Z51 shocks vrs. stock
Does anyone know what the difference between a Z51 shock and a stock shock are?
Old Nov 19, 2002 | 06:33 PM
rrobert22's Avatar
rrobert22
Default Re: Z51 shocks vrs. stock (WikdC5)
Higher damping rate I think, but then Im not really sure either :cheers:
Old Nov 19, 2002 | 06:38 PM
WikdC5's Avatar
WikdC5
Default Re: Z51 shocks vrs. stock (rrobert22)
ok...does that mean that they are stiffer or softer?
Old Nov 19, 2002 | 07:06 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
The Z51 suspension uses a slightly stiffer shock due to revised valving of the standard FE3 shock. Springs are stiffer accounting for most of the increased harshness. Front and rear stabilizer bars are larger for less body roll.
Old Nov 19, 2002 | 07:37 PM
Kenny94945's Avatar
Kenny94945
Hi,
1) The Z51 transverse springs are definitely stiffer.
2) I believe the order of stiffness (which I will define as compression dampening/ resistance):
a) FE1 (base)
b) Bilstein Heavy Duty
c) FE4 Sport Mode
d) Z51
e) Bilstein Sport
f) post 2002 Z06
g) pre 2002 Z06
h) GM's T-1 (Sachs)
Then there are Hal Adjustable 10 way and Koni adjustable 2 way and Penske infinite adjustments.
The Hal look cool - probably perfect for sreeters who drag race. Koni - may be best autocross. Penske - I want them but not at $500 a piece plus.
If I have some errors, I hope one of our co-members can update what I thought was a summary.
Old Nov 19, 2002 | 08:00 PM
WikdC5's Avatar
WikdC5
Thanks for the replies!
To Z51 shocks vrs. stock
