Headlight motorfuter
Old Feb 9, 2020 | 07:22 PM
vetpace78's Avatar
vetpace78
Default Headlight motorfuter
Hi all. I'm new to C5s (just bought an 02Z to park next to my 78 pacecar) I love the car but unfortunately it came with the notorious headlight clicking so I hit the forums and quickly bought a brass gear kit. Everything seemed to go fine but now the headlight (driver side) only goes up halfway AND its in opposite motion of the passenger side. So lights on, drivers side goes down. Lights off, driver side goes halfway up.
Any thoughts on what went wrong?
Old Feb 9, 2020 | 09:02 PM
UM Rebel's Avatar
UM Rebel
Yep. You got the bend in the in control arm backward on the driver side. Take it loose at the motor and reverse it. Welcome to C5 world.
Glad you kept your C3. I sold my '79 and still sometime regret that. Good luck.
Old Feb 9, 2020 | 09:36 PM
vetpace78's Avatar
vetpace78
Not sure what you mean by bend in the control arm. It can really only go on one way right?
I'll take another look I'm obviously missing something (other then the nut I dropped and have looked 20 minutes for)
Thanks Um Rebel.
Old Feb 9, 2020 | 09:50 PM
vetpace78's Avatar
vetpace78
I'm pretty sure I have the arm the right way. If i reverse it, it won't allow the headlight to travel far enough.
Old Feb 10, 2020 | 12:22 PM
vetpace78's Avatar
vetpace78
Ordered a new motor. What a waste of time and money with the brass gears. I'm sure the gears work great but there's definitely something else wrong here.
Old Feb 10, 2020 | 12:25 PM
vetpace78's Avatar
vetpace78
And I still haven't found that nut
Old Feb 10, 2020 | 12:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What happens if you MANUALLY position the misbehaving light to the fully lowered position when the other light is in the fully lowered position and then cycle them?
Can you manually fully raise that light?
Bill
Old Feb 10, 2020 | 01:32 PM
vetpace78's Avatar
vetpace78
Bill
Yes I can manually move it. I tried both down and both up disconnecting the battery between both. I'm baffled at this point. Especially since it worked fine before I started. It was just clicking after it went down.
Old Feb 10, 2020 | 04:35 PM
UM Rebel's Avatar
UM Rebel
If you raise them manually then cycle the lights on and off do both go down normally?
Old Feb 10, 2020 | 04:48 PM
vetpace78's Avatar
vetpace78
No. Always opposite each other.
Old Feb 10, 2020 | 04:56 PM
vetpace78's Avatar
vetpace78
It acts like the wires are reversed. I don't think it was even possible to put back together any other way but if the brushes were switched could it change direction? Or the metal housing was put on 180 the wrong way?
Old Feb 10, 2020 | 05:03 PM
vetpace78's Avatar
vetpace78
Btw it still binds halfway up or down which it didn't do before I started. (No its not the arm going the wrong way. The short bump stop arm is between the longest distance between bump stops)
Old Feb 10, 2020 | 07:12 PM
Joewass65's Avatar
Joewass65
Reverse the arm. I’ve been down this road before.
Old Feb 10, 2020 | 08:20 PM
vetpace78's Avatar
vetpace78
Seriously it's not the arm! I totally understand that could happen especially to someone new to the c5 headlights like me.
I just pulled the motor out of the housing (again)
I might have put the bushings in upside down.
It does fit either way. When I first pulled it apart I was more concerned about the tiny springs that got away from me more then the direction the plastic piece that held them and the brushes in place. I put it back together and it even seems to turn more freely. I don't have time to put it all back together tonight but I'll be sure to let you all know the verdict.
Old Feb 11, 2020 | 09:38 AM
vetpace78's Avatar
vetpace78
It's official, I'm an idiot. I had put the brushes in upside down. It now works perfectly!
Unfortunately I live in Minnesota and we just got a foot of snow. It will probably be another 2 months before i can put the headlights to use.
Thanks for the support!
To Headlight motorfuter
