Mobil Synthetic Lubricant
Old Feb 10, 2020 | 05:40 PM
Bills03Coupe's Avatar
Bills03Coupe
Default Mobil Synthetic Lubricant
I plan on using Mobil 75W-90 Synthetic gear Lubricant LS
To change my differential lube. This product already contains
the friction modifier. Do I need to add any additional modifier?
Old Feb 10, 2020 | 06:06 PM
Joewass65's Avatar
Joewass65
I would only use 88862624. Gm recommended. 1.8 quarts.
Old Feb 10, 2020 | 06:39 PM
493lszosix's Avatar
493lszosix
You don’t need to add any extra
Old Feb 10, 2020 | 07:16 PM
CinciZ06's Avatar
CinciZ06
You do not need to add any modifier. Many of us run this lubricant, and the modifier is already added by Mobile1.
Old Feb 10, 2020 | 08:46 PM
gimp's Avatar
gimp
If it already contains modifier, usually you don't need more. If you hear issues after replacing the fluid, then add some more and see if it goes away.
Old Feb 19, 2020 | 11:46 AM
Bills03Coupe
I saw an ad for this Part number 88862624, and its stated for use in 2007 and later differentials. First I've heard of this.
Old Feb 19, 2020 | 02:05 PM
GCG's Avatar
GCG
As mentioned above, there's no need to add more friction modifier. This is a perfectly fine gear lubricant, used by many forum members.
Old Feb 19, 2020 | 05:50 PM
Hoganryan40's Avatar
Hoganryan40
never trust ads. This is gm certified and recommended. Don’t put anything else in your diff.
To Mobil Synthetic Lubricant
