Active Handeling
Old Feb 13, 2020 | 07:44 PM
CEEZROCK's Avatar
CEEZROCK
Default Active Handeling
Hello....need to service active handling on my C5.....any recommendations??
Old Feb 13, 2020 | 09:00 PM
Joewass65's Avatar
Joewass65
What codes are you getting?
Old Feb 13, 2020 | 10:01 PM
StingrayRebel's Avatar
StingrayRebel
codes and what year is the car?
Old Feb 14, 2020 | 10:43 AM
CEEZROCK's Avatar
CEEZROCK
Not sure about codes....displays "Service vehicle soon" "Service active handling"
Old Feb 14, 2020 | 10:45 AM
CEEZROCK's Avatar
CEEZROCK
2004....Not sure about codes....displays "Service vehicle soon" "Service active handling"
Old Feb 14, 2020 | 11:11 AM
bobgroger's Avatar
bobgroger
You need codes to fix this. Search how to pull the codes. Hint: You use the instrument cluster
Old Feb 14, 2020 | 11:25 AM
Joewass65's Avatar
Joewass65
Most likely 1214 or 1287. Fix depends which code.
Old Feb 14, 2020 | 11:38 AM
Will_M1911's Avatar
Will_M1911
1) Turn on the ignition but don't start the engine.
2) Press the "reset" button to turn off any warning messages
3) Press and hold "options" and
4) While holding "options", press "fuel" four times within a 10-Second period.
The codes will begin to flash across the display. Anything with a "-C" suffix is a current code. List those out and I'm sure someone can provide a fix.
Old Feb 14, 2020 | 06:43 PM
CEEZROCK's Avatar
CEEZROCK
Thanks guys...I will look into it.
Old Feb 16, 2020 | 08:09 PM
CEEZROCK's Avatar
CEEZROCK
Hello....so these are the codes I saw.....not sure what they mean?
28-TCS, C1287 H, C1288 H
60-IPC, B0516 H, B0521 H
A0-LDCM, B2282 H, B2286 H, B2284 H, U1064 H
A1-RDCM, B2283 H, B2287 H, B2285 H, U1064 H
Old Feb 16, 2020 | 09:38 PM
Joewass65's Avatar
Joewass65
Clear them all and drive the car to see what comes back.
but I’m guessing 1287 is your problem. Need a new steering sensor.
See if the car jerks to one side when the activity handling light comes up. Tell tale sign of a bad sensor. Hopefully your car is 2001 or newer.
Old Feb 16, 2020 | 09:39 PM
UM Rebel's Avatar
UM Rebel
  • 28-TCS, C1287 H, C1288 H
  • C1286 Steering Sensor Bias Malfunction
  • C1287 Steering Sensor Rate Malfunction
Looks like your Steering wheel Position Sensor is failing. Common problem.
What year is your car? SWPS is not available for older models. Newer models part is about $65 but it's a PITA to replace
Suggest you unplug the sensor at the base of steering column until you get it replaced. Can cause some unexpected jurks on the brakes.
Good luck
Old Feb 16, 2020 | 09:53 PM
02torchred's Avatar
02torchred
^ Yep except you can check and clear codes with the engine running, I've done it many times.
Old Feb 16, 2020 | 10:19 PM
CEEZROCK's Avatar
CEEZROCK
Thanks guys.....that's exactly what it does, jurks on the brakes. Car is 2004....I will replace the sensor.
Old Feb 17, 2020 | 04:20 AM
Grandpa1's Avatar
Grandpa1
There is a current post showing a member using some electrical cleaning spray on his sensor and it working out pretty well.
You might do a search and find it and give it a shot.
Might work for you and save you a lot of money.
Might not too!
It cost me around $600 to have my SWPS changed out.
Good luck!
Old Feb 18, 2020 | 03:30 PM
UM Rebel's Avatar
UM Rebel
Might not too!
Good luck!
I tried the cleaning spray. It did not work for me.
Old Feb 18, 2020 | 04:18 PM
UM Rebel's Avatar
UM Rebel
There are a few videos on how to install a new SWPS. Here's one
Old Feb 19, 2020 | 05:52 PM
Hoganryan40's Avatar
Hoganryan40
Have a shop replace the steering sensor. It’ll cost some money but it’s worth it. Unless your a well versed mechanic don’t attempt this.
To Active Handeling
