So.... after scraping the front spoiler underneath the car so many times, it finally broke off. Any recommendations on where I could buy a new one? Also, how do I know if I need to just buy the center piece or all three pieces?
Just replaced mine recently. GM 10401458
you can find it at any gm wholesale parts online. Here’s one in New Mexico that I use all the time. You may be able to find a cheaper China made reproduction but it didn’t fit right for me and wasn’t made from the right material. I went with the more expensive oem.
My center spoiler is starting to dangle since part of it has broken. But I haven't done anything about that yet... contemplating going with this one, though:
My center spoiler is starting to dangle since part of it has broken. But I haven't done anything about that yet... contemplating going with this one, though: https://www.amazon.com/gp/product/B00F5Q9JOM/
I think I will go with it too. It's a free return. So if it doesn't fit for some odd reason you can return.
that’s the repro one I was talking about. Didn’t fit for me. And the angle was off. Car ran much hotter because the air wasn’t being directed properly. But let me know if it works for you.
Ok, I ended up ordering it off Amazon... lets see what happens. If it doesn't work, I can just return it.
I can't seem to find the two bolts that hold the center piece. Do you happen to know the size of those bolts? Thinking I can go to a hardware store and get them.
i can look in a few days when I’m back home. How was the old one held on if the bolts are missing? It’s a pretty big bracket that’s bolts to the lower radiator support.
That is what i'm confused about. Maybe i'm looking in the wrong spot. I"ll look again. Thank you for your help!
is it a M6 x 1mm x 30mm bolt?
Avoid the Zip Corvette one, too. I will be returning the one I received today...was unable to install the center air dam piece because the sheetmetal beam (located on the backside) does not have the correct horizontal or vertical curvatures to be fitted on the car. Seriously. You'd think basic s**t like that would be covered in the product / supplier review. Obviously the "monkey see monkey do" product knock-off was a big effing failure in this case.
