Power gains !
Old Feb 13, 2020 | 10:42 PM
Speedy007's Avatar
Speedy007
Default Power gains !
My next piston idea for durability.927 pin 3.903 +12cc with 12.5-12.8 with a roughly compression ratio with 64cc chamber along with boost line 2000hp rated rods /arp bolts, and the 3.622 flat plan crank ! Boosted roughly 12-15lbs including yes if my vara power duct! Before I go pulling the trigger on this what do you all think? Porting our only the exhaust valve just enough to say it was done ! Along with the throttle body mouth velocity stack and intake inlet and runner exists again just enough to say it was done ! Cam is ls9 / ls3 timing all billet ! Maybe a new oil pump / pan & seals if I feel like affording them !
