Honker install now throwing codes
Old Feb 22, 2020 | 10:10 PM
c5coast's Avatar
c5coast
Default Honker install now throwing codes
Had Callaway Honker installed, now seeing codes. P0101, Cleaned MAF and replaced insulating grommet post air filter. Now throwing P0171, P0174 as well as P0101. I can clear codes but idles rough. Runs fine on the road otherwise. Could the MAF be bad? 60k on the clock. Ran fine prior to Honker install. Do I need to have it Dyno'd? Do I need to replace MAF? Bummed that these codes are popping up. 2004 C5 MN6. Only modifications is a Corsa cat back system and the new Honker install. I keep seeing mention of resetting? Not sure what that entails.
Old Feb 22, 2020 | 10:47 PM
PNW_C5Z's Avatar
PNW_C5Z
I doubt the Honker has this issue, but...issues can pop up after intake installs because of how sensitive/precise the MAF is with its measurement (changing position of the MAF inside the housing, moving it closer to or further away from the TB, etc). If you cleared your codes, you'll need to get some drive-time on it so the OBD can perform its readiness checks, and so that the PCM can learn the hardware change. You shouldn't need a re-tune for an off the shelf intake, but it could take a tank of fuel worth of driving for the PCM to adapt. You can "short cut" the idle relearn procedure by leaving your battery disconnected for a while - then let your car idle for 20 mins (10 without AC, and 10 with AC on).
Old Feb 23, 2020 | 12:00 AM
c5coast's Avatar
c5coast
Thanks, I'll try the shortcut method. I drove it for 60 miles continuous and the codes came back? I'll disconnect the battery and idle it.
Old Feb 23, 2020 | 08:53 AM
bonesbrakr's Avatar
bonesbrakr
Sounds like someone else installed it. Any vacuum leaks? Any unconnected hoses?
Old Feb 23, 2020 | 09:11 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
With the 2 new lean codes I’d recheck all the connections !!...you probably have a vacuum leak somewhere !!
Old Feb 23, 2020 | 11:48 AM
scorpiofox69's Avatar
scorpiofox69
Old Feb 23, 2020 | 12:36 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
I seem to remember when I installed my Honker that the MAF had to be relocated...
Old Feb 23, 2020 | 05:52 PM
c5coast's Avatar
c5coast
MAF was relocated next to TB. Work performed at a Corvette Shop. When the first code P0101 showed up I noticed shop had broken the "insulating grommet" on the air box, post filter. Found a grommet to fit, was sucking in raw air from engine compartment. Cleaned the MAF and reinstalled. Code still present with a couple of friends P0171 & P0174. I'll give the disconnect battery , reconnect and idle a try. I'VE LOST FAITH IN THE SHOP I TOOK IT TO. I'll be seeking another shop in SoCal to resolve if need be. I'll also check vacuum lines for leaks. I feel I've been sabotaged.
Old Feb 23, 2020 | 10:21 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I have a 04 with manual trans. Car was fine until I installed a Vararam.I also get p0171 and p0175. No leaks and cleaned the MAF. The only fix is a tune. You need to look at your fuel trims. I bet they are at +25. The computer thinks it's lean and is making the car run rich. The computer won't adjust the trims any further than that so it sets the lean code. I have a Diablo Trinity and I'm able to adjust for it. Once I made the adjustments no codes and fuel trims come in to where they're supposed to be. Not sure if I'm totally happy with my solution but I'll eventually get a real tune.
Old Feb 23, 2020 | 10:46 PM
Hoganryan40's Avatar
Hoganryan40
I did an airaid. No issues at all.
Old Feb 24, 2020 | 07:57 PM
scorpiofox69
Same here.
Old Feb 24, 2020 | 08:28 PM
Speedy007's Avatar
Speedy007
Naturally those codes would be going off because somethings up with the MAF or wiring ! Do you install it back the right way ? The screen should be towards the bumper and the split is vertical up and down! Any pictures where the maf is ?
Old Feb 24, 2020 | 08:29 PM
Speedy007's Avatar
Speedy007
My car was tuned for a vara I still have the file as well!
I would relocate again down stream coupler to honker !
Old Mar 7, 2020 | 09:27 PM
c5coast's Avatar
c5coast
MAF relocated per Callaway instructions. When I pulled it for cleaning it appeared clean. Cleaned it anyway. That was before it started throwing the lean codes.
Old Aug 6, 2020 | 07:30 PM
c5coast's Avatar
c5coast
Took it to another shop...vacuum leak on intake manifold. They fixed it and the original shop that did the install is out of business now.
To Honker install now throwing codes
