coolant sensor quit working
Old Mar 6, 2020 | 03:40 PM
Jumpjets's Avatar
Jumpjets
Default coolant sensor quit working
Team, Please help me out!
I just swapped out a faulty oil pressure sensor on my 2000 C5 bone stock LS1. In the process, I accidentally cut the engine coolant temp sensor wires on the driver side cylinder head. I performed a quality wire repair, with shrink wrap. The sensor works properly when the ignition key is in the "run" position, but the engine is off. When I start the engine, however, the engine temp gauge jumps up to 260*F, and the DIC says "ENGINE TEMP xxx*F"
Anyone have this issue before, or have any clues for me?
Old Mar 6, 2020 | 04:48 PM
Jumpjets's Avatar
Jumpjets
I cleared the DTC codes, and that seems to have fixed it. The gauge and DIC function as they should.
easy fix!
